05-26-2020, 02:30 PM | #1 |
Can a cracked block be fixed?
So this’s morning I pulled the left head from a ‘46 Mercury.
It is badly warped but the lock has a crack from the intake seat to the cylinder. And the sleeve has moved up some. Should a 46 Merk have sleeves? Can the crack be fixed? Will lt be reliable? |
05-26-2020, 02:48 PM | #2 |
Re: Can a cracked block be fixed?
So THIS morning I pulled the head from a ‘46 Mercury coupe.
I do know how to write. Aaron Griffey Beautiful down town Hayward. CA |
05-26-2020, 02:53 PM | #3 |
Stitching and a sleeve is the usual fix for it.
As long as you can drill the end of the crack down in the valvebowl it´s repairable. |
05-26-2020, 04:42 PM | #4 |
A '46 would not have sleeves originally so it's been repaired previously. The sleeve that's moved will have to come out before inspecting the block for extent of crack and possible repair. As Murre says, getting to the ends of the crack is important.
"It don't take but country smarts to solve the problem" (Smokey Yunick) '41 Merc Town Sedan / 260" 8CM engine '66 Fairlane four door / "warmed up" 302 |
05-26-2020, 06:01 PM | #5 |
I had a 59 block sleeved to take care of a tiny pinhole leak in the cylinder wall below to piston travel area. The shop that sleeved it use some type adhesive product like Locktite between the cylinder wall and sleeve to ensure the sleeve didn't move. If you need the name of the peoduct I can get for you form the machine shop. As pointed out, usually pinning, (stitching), will solve most crack problems. On the East cost we have a wizard, (Frank Casey), that has been doing for years.
05-26-2020, 06:17 PM | #6 |
