Old 12-10-2019, 02:17 PM   #1
3twinridges
3twinridges's Avatar
Default Optima 6V battery charge
On a 6V optima redtop battery, what should the testing voltage be on a 100% charged battery?
JB
3twinridges is offline   Reply With Quote
Old 12-10-2019, 02:24 PM   #2
Black Fifty
Black Fifty's Avatar
Default Re: Optima 6V battery charge
6.3 volts. 2.1 per cell.
Black Fifty is offline   Reply With Quote
Old 12-10-2019, 02:54 PM   #3
leon bee
6.3 here also.
leon bee is offline   Reply With Quote
Old 12-10-2019, 03:15 PM   #4
3twinridges
My charger shot it up to about 7.0v and still showed charging not complete.
JB
Old 12-10-2019, 03:49 PM   #5
philipswanson
That sounds fine. Right after charging the voltage will be higher. After charging, let it sit for a few hours, then take a reading. Use a quality fully automatic charger not a cheap one with constant amps.
philipswanson is offline   Reply With Quote
Old 01-05-2020, 09:42 PM   #6
3twinridges
Got it figured out. My harbor freight multimeter was over a bolt off. Bought a good quality one and I am at 6.3. Thanks
JB
Old 01-05-2020, 09:52 PM   #7
Dave/Green Bay
What type of charger do you use? Dave/Green Bay
Dave/Green Bay is offline   Reply With Quote
Old 01-05-2020, 09:55 PM   #8
3twinridges
It’s a schumacher 6v charger/maintainer.
JB
Old 01-06-2020, 02:01 PM   #9
drolston
drolston's Avatar
Most of these smart chargers are too smart for their own good. Like if a battery gets completely discharged, they will indicate failed battery and not even try to start charging. I use an ancient Western Auto trickle charger to get the things started, and then hook up the smart one.
Old 01-06-2020, 05:41 PM   #10
Black Fifty
Very good point about the "smart" chargers. I've had the same experience.
Old 01-07-2020, 11:55 AM   #11
FL&WVMIKE
FL&WVMIKE's Avatar
I've had the best luck NOT keeping these batteries on the trickle charger (Battery Tender) 100% of the time. I'll put the charger on for a day or so once every month or so, but leave it at that. I think leaving AGM batteries such as the Optima on chargers 24/7 is bad for them.
I have a 12V Optima in the mustang that still works great... and is dated 02/06
Good Luck
Mike Jr. here. I get on here every few months to check messages, and look through his almost 500 saved messages for information on the '29 and '34 I still have. A lot of very nice people on here. He truly enjoyed Ford Barn.
FL&WVMIKE is offline   Reply With Quote
Old 01-07-2020, 12:43 PM   #12
blucar
blucar's Avatar
I have used a "Battery-Tender" on several of my batter's, for many years, including AGM and/or Optama's, never had what I would call a failure. I did have a problem if I left the 'Tender' disconnected to long.
Bill.... 36 5 win cpe
Old 01-07-2020, 04:03 PM   #13
supereal
supereal's Avatar
We use the Battery Tender all winter. It keeps our Optima batteries ready for the next drive. Most of our Optimas last years with no problems. Glass Mat batteries require low charging rates to prevent damage.
supereal is offline   Reply With Quote
Old 01-07-2020, 05:06 PM   #14
JSeery
JSeery's Avatar
Battery charge table:
Old 01-09-2020, 01:10 PM   #15
solidaxle
solidaxle's Avatar
I have had good results with this one
solidaxle is offline   Reply With Quote
Old 01-10-2020, 06:10 AM   #16
3twinridges
I am going to return the battery I think. I can’t get the battery to hold a charge. It dropped from 6.36 volts to 6.0 volts overnight. I think it has a bad cell.
JB
Old 01-11-2020, 04:33 PM   #17
4dFord/SC
4dFord/SC's Avatar
JB
My Optima typically shows 5.87 volts after sitting for awhile, but it always starts the car.
4dFord/SC is offline   Reply With Quote
Thread Tools
Display Modes
