Old 10-30-2019, 03:56 PM   #1
SimplyCosmic
Default Rainy Day Thought
Vacuum-powered wipers should have "For Entertainment Purposes Only" printed on them.
SimplyCosmic is offline   Reply With Quote
Old 10-30-2019, 04:04 PM   #2
Synchro909
Synchro909's Avatar
Default Re: Rainy Day Thought
A rainy day - not sure I can remember the last one. Things are so dry here that I'd love to be "entertained" by a vacuum wiper!!
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 10-30-2019, 04:16 PM   #3
SimplyCosmic
While I'm sure that a proper restoration would help, for me it's a matter of height. Even at 5'10", my eye-line settles at the top of the window. So the area cleaned by the wiper is too small, too low, and to the right of where I look out.
Fortunately, as many suggest, the straight, vertical windshield works well with RainX.
Old 10-30-2019, 04:23 PM   #4
burner31
burner31's Avatar
Had vacuum wipers on my '49 Chevy pick-up back in the early '70's, vacuum wipers sucked back then too.
Electric on my A today.
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 10-30-2019, 05:59 PM   #5
WHN
We have a vacuum wiper on our 29. Problem is, it hasn’t been out in the rain in almost 50 years.
WHN is offline   Reply With Quote
Old 10-30-2019, 07:23 PM   #6
Richard in Anaheim CA
Richard in Anaheim CA's Avatar
We should be so lucky to have a rainy day here in "up in flames" California
Richard in Anaheim CA is offline   Reply With Quote
Old 10-30-2019, 07:26 PM   #7
Vacuum wipers work "GREAT" going downhill with your foot off the gas.
If you can't accomplish that full time, Rainex !
Old 10-30-2019, 07:28 PM   #8
panhead_pete
panhead_pete's Avatar
Hi Burner 31 what electric setup are you using please?
Looking for an unrestored 33 34 3W or 5W coupe.
Thanks
panhead_pete is offline   Reply With Quote
Old 10-30-2019, 08:03 PM   #9
bdtutton
When my vacuum wipers are working well with a new blade they work OK when I am driving at lower speeds and around town. As long as you have a lot of vacuum they do OK. They start having a lot of problems when you are climbing long uphill grades and there is no vacuum to drive them or when you are driving 45mph plus and the wind lifts the wiper off the windshield. The good news is RainX on the flat windshield does work wonders.
bdtutton is offline   Reply With Quote
Old 10-30-2019, 08:36 PM   #10
Synchro909
Synchro909's Avatar
Rainex is all I use. The wiper (Hand operated) is only there to satisfy the constabulary. Vac wipers suffer the same problem as cars that relied on a vacuum tank for fuel supply. Henry at least got that part of his design right.
Old 10-30-2019, 08:57 PM   #11
arnhemmer
I call mine intermittent wipers.
arnhemmer is offline   Reply With Quote
Old 10-30-2019, 09:22 PM   #12
Dodge
I had a 1949 Ford with them. There is a long grade near us and I remember going up the grade in the rain long before rain-x. You used to let off at the bottom of the grade for a second and let them work, then when you couldn’t see again let off for a second and they’d go nine million miles an hour then start the whole process all over again. What a treat.
Thank god they started using electric wipers more.
Dodge is offline   Reply With Quote
Old 10-31-2019, 07:49 AM   #13
TerryO
TerryO's Avatar
+1 Rainex works much better than the wipers.
TerryO
TerryO is offline   Reply With Quote
Old 10-31-2019, 08:06 AM   #14
jwilliams81
jwilliams81's Avatar
I had my vacuum wiper restored. The unit itself works amazing. It does an ok job of clearing the windshield, but I do use Rain-X still.
Here is a video of the wiper in action on the way to work:
https://www.youtube.com/watch?v=9oTGqbkZmiA
1931 Murray Town Sedan. Black body with Apple Green pin stripe.
1923 Model T Touring with electric start. Low radiator
Cincinnati, Ohio
jwilliams81 is offline   Reply With Quote
