Old 11-17-2019, 02:10 PM   #1
Werner
Werner's Avatar
Default Remove inner oil pan
Hallo,
does anyone have a suggestion how I pull out the corrugated iron insert-pan off the whole oil pan? (Tiny rust holes!)
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 11-17-2019, 02:12 PM   #2
dbaldwi3
dbaldwi3's Avatar
Default Re: Remove inner oil pan
Believe it or not a Wooden baseball bat slid into the side and give it a good pop it will come out.
dbaldwi3 is offline   Reply With Quote
Old 11-17-2019, 02:17 PM   #3
john charlton
john charlton's Avatar
Put a piece of old junk carpet on the ground and drop the pan upside down on the carpet it will just pop out . You might have to assist gravity a litle bit .Dont do it on bare concrete .
John in no weather today Suffolk County England .
Old 11-17-2019, 02:36 PM   #4
Dick M
Dick M's Avatar
Send a message via Yahoo to Dick M
Best to put the pan in a plastic garbage bay prior to dropping. It will contain the sludge!!
Dick M is offline   Reply With Quote
Old 11-17-2019, 03:17 PM   #5
Tom Endy
Tom Endy's Avatar
A baseball bat works well. If you don't have a baseball bat handy a hammer with a wooden handle will also work. Insert the handle into the hole for the oil pump. put you foot on the pan to stabilize it and give it a jerk, it will come out.
Tom Endy
Old 11-17-2019, 03:49 PM   #6
Kurt in NJ
Kurt in NJ's Avatar
if you slip the other side under the overhang of a step ---arm of the lift, or watever is handy to hold the pan then the baseball bat gives more control ---less splashing of gook
Old 11-17-2019, 04:00 PM   #7
The Master Cylinder
The Master Cylinder's Avatar
Hmmm, do they have baseball bats in Germany??
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 11-17-2019, 04:05 PM   #8
Ed in Maine
The easiest of all way is to place a C-clamp inside the oil pump opening and lay a 2x4 in. piece of wood across the top of the oil pan. Simply wind up the C-clamp and out pops the dipper try. Ed
Old 11-17-2019, 09:46 PM   #9
History
History's Avatar
That's the way I'd read but couldn't remember, excellent idea.
History is offline   Reply With Quote
Old 11-17-2019, 11:00 PM   #10
PalAl
PalAl's Avatar
I do it this way and it is sooooo easy
PalAl is offline   Reply With Quote
Old 11-17-2019, 11:04 PM   #11
PalAl
PalAl's Avatar
Make sure when you replace the baffle it snaps totaly in place, check and double check! You do not want to drop the pan for a do over.
Old 11-18-2019, 11:03 AM   #12
PalAl
PalAl's Avatar
Remove slot screw plug and insert holder, remember to remove holder and insert plug when job is complete.
Here is another version of the holder
Old 11-18-2019, 11:04 AM   #13
PalAl
PalAl's Avatar
Whoops... wrong thread...LOL
Old 12-10-2019, 02:38 PM   #14
Werner
Werner's Avatar
I did it similar to PalAl. That worked well, thanks for the hint!
Again, it is easy to see how clean the interior of a motor is, if it is lubricated with HD oil SC. Minimal hardly any residues in the oil pan.
Werner
Citroen 11 CV, 1947
Old 12-10-2019, 06:02 PM   #15
CWPASADENA
CWPASADENA's Avatar
The last time I needed to remove the dipper tray from an oil pan, I had a 28-29 headlight bar on the bench that I tried to see if it would be a good pry bar. The curve on the end and the flange for the mounting bolts works perfectly as a pry bar. Use your foot on the pan and with the headlight bar, the dipper tray will pop right out.
My experience,
Chris W.
CWPASADENA is offline   Reply With Quote
Old 12-10-2019, 08:26 PM   #16
David R.
I did like John said: tied it up in trash bag, held it up about head high, dropped it top side down on a piece of plywood on concrete driveway and popped right out first try. Boy was it grungy though!
David R. is offline   Reply With Quote
Old 12-11-2019, 07:51 AM   #17
davehc
davehc's Avatar
12-01-2018, 03:59 PM #1 davehc
Easy Oil Pan Baffel Removel
Thought I would share how I removed the baffle from my oil pan after I finally got if off , for those who haven't tried this yet . . I used my slide hammer with the small hook , with a rubber cap to protect the baffle , hooked it in the small hole side of the baffle , and it popped out on the second slide .
davehc is offline   Reply With Quote
Old 12-11-2019, 02:20 PM   #18
Jim Brierley
When you have the dipper tray out and cleaned, hold it up so sunlight will shine on it and check for rusted through spots. Water will settle in the dipper troughs and rust them.
Old 12-11-2019, 03:15 PM   #19
Werner
Werner's Avatar
Guten Abend Jim,
here at this point I have to enjoy myself. When I had the tub solved yesterday, I saw some rough areas (like rice) below. I soldered them hard today!
Werner
Citroen 11 CV, 1947
