Old 10-11-2019, 03:07 PM   #1
Merc Cruzer
Merc Cruzer's Avatar
Default Fall In The Rockies
As you might have heard, we got our first snow storm two days ago. It was 28 degrees this morning when I filmed this. Hope you enjoy it.
https://www.youtube.com/watch?v=V5biC4qjjTE&t=85s
Merc Cruzer is offline   Reply With Quote
Old 10-11-2019, 06:42 PM   #2
RalphM
RalphM's Avatar
Default Re: Fall In The Rockies
Nice drive!
We are getting snow as well!
RalphM is offline   Reply With Quote
Old 10-11-2019, 07:00 PM   #3
RKS.PA
RKS.PA's Avatar
Very COOL Merc!! Thanks for posting..... that beautiful scenery is a little rare around these parts!!
RKS.PA is offline   Reply With Quote
Old 10-11-2019, 07:07 PM   #4
scicala
scicala's Avatar
Nice drive and beautiful bright blue sky.
Sal
Old 10-14-2019, 09:45 PM   #5
50fordcoupeman
50fordcoupeman's Avatar
Very nice........thank you!!
50fordcoupeman is offline   Reply With Quote
Old 10-14-2019, 09:52 PM   #6
petehoovie
petehoovie's Avatar
Too bad about the crack in the road....
The only thing nice about being imperfect is the joy it brings to others....
"Silver rings, your butt! Them's washers!"
"We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969
https://www.youtube.com/watch?v=7NReUd2_0u0
Old 10-15-2019, 08:31 AM   #7
Merc Cruzer
I prefer 3/4 shots but I can always use one of these.
Old 10-15-2019, 08:49 AM   #8
Pat/Ohio
Pat/Ohio's Avatar
Thanks Roy! I had to retrieve my coat from the hall closet!
Pat
Pat/Ohio is offline   Reply With Quote
Old 10-15-2019, 10:23 AM   #9
RalphG
RalphG's Avatar
What a great scenic video (and sound). Was that a slight stumble when you hit the gas at the 3:30 mark? I'm guessing you have a good working heater in the Merc. Mine has been disconnected as I think the core leaks.
RalphG is offline   Reply With Quote
Old 10-15-2019, 01:10 PM   #10
petehoovie
petehoovie's Avatar
Nice Shots!
Old 10-15-2019, 03:15 PM   #11
Merc Cruzer
The issue is that I have the heat riser blocked off to the calibrator for summer running (fewer issues with vapor lock), so the gas is cold, rather than being preheated to a vapor state. It was 28 degrees when I made the video, so all my efforts to keep the engine running cooler, basically kept it from warming up too. It's going to be 80 here on Thursday, yet we have had the heat on in the house for the last week. Just another Fall day here in the Rockies.
I do have a good heater, but it is used more to taking heat off the engine on a 90 degree day, rather than heating up the driver during the winter. When I drive it on the dry days during the winter months, the heat coming through the firewall and floor is just about enough to keep you warm with the top up.
Old 10-15-2019, 05:55 PM   #12
RalphG
RalphG's Avatar
Originally Posted by Merc Cruzer View Post
The issue is that I have the heat riser blocked off to the calibrator for summer running (fewer issues with vapor lock), so the gas is cold, rather than being preheated to a vapor state. It was 28 degrees when I made the video, the heat coming through the firewall and floor is just about enough to keep you warm with the top up.
I figured it was probably a cold weather issue. Does yours have the heat riser control down in the right side exhaust manifold like mine has?
Old 10-15-2019, 07:48 PM   #13
Merc Cruzer
It did when it had a single exhaust (I still have the manifold with the heat riser, in a bin some place), but now it has a duel exhaust and that side is just capped off.
On the drivers side, I have the single manifold.
Old 10-15-2019, 08:34 PM   #14
RalphG
RalphG's Avatar
Is that left side exhaust manifold a special after market part? I don't recall dual exhaust being an option on the 52-53 Mercs. My front cross over pipe has a small hole burnt in it that might be an excuse for me to go full dual exhausts.
Old 10-16-2019, 12:26 AM   #15
Tinker
Tinker's Avatar
Great car, great pictures!
Old 10-16-2019, 08:49 AM   #16
Merc Cruzer
https://www.ebay.com/itm/1952-1953-F...8AAOSwcL5ddSYT
1952 1953 Ford car Factory Dual exhaust LH exhaust manifold EAB-9431-A
