Old 07-27-2019, 01:40 PM   #1
Minn-Tex Lee
Minn-Tex Lee's Avatar
Default Lost a wind wing
My 1931 Roadster wind wing glass is captured with two sets of clamps.
They are rubber backed for additional friction, but they do not seem to have sufficient holding power. Is there a more positive way to secure these wing windows?
Thanks,
Lee
Minn-Tex Lee is offline   Reply With Quote
Old 07-27-2019, 01:42 PM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Lost a wind wing
Thanks,
Lee
Yep, modify the brackets to mimic original brackets, and use the correct clamps. The Vintique brackets do not hold.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 07-27-2019, 01:47 PM   #3
The Master Cylinder
The Master Cylinder's Avatar
Typical...
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 07-27-2019, 01:54 PM   #4
jb-ob
Automotive black two faced tape.
jb-ob is online now   Reply With Quote
Old 07-27-2019, 02:02 PM   #5
Werner
Werner's Avatar
Hallo Lee, I had the same problem. It is important that the retaining clips are fed thick enough at the rear end, so when tightening the screws firmly press the other end on the glass. In addition, I have made some contact glue on the rubber pads.
Beste Gruesse aus Deutschland,
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 07-27-2019, 04:37 PM   #6
Synchro909
Synchro909's Avatar
I took the glass out and replaced it with clear acrylic sheet. It's much lighter and the clamps grip it better than glass. I've done about 50,000 miles since then and although the acrylic is getting a bit scratched, they are still there. That reminds me - I must replace the scratched wings.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 07-27-2019, 06:26 PM   #7
ronn
went through the same thing last month, towing the roadster from VT to NY. In all fairness, the rutted roads in NY were hell on the trailer truck and car. surprised I didnt lose more-pot holes were craters!
found a single wind wing on ebay and also the lost lower clasp
Old 07-27-2019, 07:48 PM   #8
SAJ
SAJ's Avatar
I use 3M's grey double side adhesive foam tape ( the one with red release film each side). The one for outside use holding I think 5 kg per square inch -11 pounds that is.
Depending on glass thickness I use it with or without one or bofh of the rubber gaskets. It works OK with Viintiques flat-backed repops or with originals. If using on originals which are "hollow" I flatten them by filling with body filler to maximise the tape bond area especially if the correct rubber gaskets that fit inside the hollow bracket are not available.
I have fixed many members roadsters like this in car parks after their wind wings fell off and lay undamaged on the running boards - sort of small miracle that often happens.
SAJ in NZ
SAJ is offline   Reply With Quote
Old 07-27-2019, 09:23 PM   #9
whirnot
whirnot's Avatar
If you use polycarbonate instead of acrylic, it won't scratch as easily.
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
Smith Motor Compressor
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 07-27-2019, 09:24 PM   #10
chrs1961815
chrs1961815's Avatar
The reproduction brackets by Vintique are junk. The brackets are not the right shape, the plating is cheap, and the screws are horrible quality metal so the slots become jagged and they are a pain to tighten. Originals are your best bet for sure, though they are not the easiest to find. I got fed up with the brackets so I have the wind wings sitting on the table right now waiting for reattachment when I get the chance.
Any adhesive will improve the quality and your peace of mind in the meantime.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 07-27-2019, 09:48 PM   #11
quickchange
quickchange's Avatar
Take vintique clamp , one 1/2 of top clamp, drill 1/8 hole in it but not right through , mark it on the glass , drill 1/8 hole through the glass, put short piece of brazing rod in the hole , refit as normal , no way will you ever loose a glass again, the rod takes the weight , done dozens for our rough roads , never had one fail, A simple solution,
quickchange is offline   Reply With Quote
Old 07-28-2019, 09:52 AM   #12
SSsssteamer
SSsssteamer's Avatar
I replaced the cheap Chinese metric screws and bolts with USA SAE fasteners. Made a world of difference and haven't had anymore problems. From above: If you have tempered glass wind wings, do not drill holes in them. They will self destruct if you do. Laminated glass is easy to drill holes through.
SSsssteamer is offline   Reply With Quote
Old 07-28-2019, 09:00 PM   #13
Conaway2
Conaway2's Avatar
Who is the preferred vendor for the wind wing clamps, if you. Don’t want to use the Vintique parts ? I drove to a meet this past weekend and almost lost a wind wing......
Many thanks !
Jim
Conaway2 is offline   Reply With Quote
Old 07-29-2019, 06:07 AM   #14
ronn
ebay usually has stray wing clamps.........
Old 07-29-2019, 07:51 AM   #15
chrs1961815
Many thanks !
Jim
I think the only repro ones the vendors sell are Vintique. I am not sure about A & L.
Thread Tools
Display Modes
