Old 05-30-2019, 08:12 PM   #1
hotrodA
hotrodA's Avatar
Default 32 Seat adjuster spring?
Is this adjuster spring for Tudor driver's seat repro'd or I am hoping to get lucky, or close, at my friendly hardware store? Searched with no luck.
hotrodA is offline   Reply With Quote
Old 05-30-2019, 08:31 PM   #2
Krylon32
Default Re: 32 Seat adjuster spring?
When I did my deuce delivery I had a picture of the spring so I went to my local True Value Hardware store ans he had a large board with all the springs available. I found one that worked perfect.
Krylon32 is offline   Reply With Quote
Old 05-30-2019, 09:55 PM   #3
hotrodA
hotrodA's Avatar
Thanks!
Old 05-30-2019, 10:26 PM   #4
TomT/Williamsburg
TomT/Williamsburg's Avatar
Hmmmm - the body of my new ride was from a restored car. It was like a ratchet setup and a piece bolted to the floor to lock it down in different positions. You twist the handle and the seat will go forward or back - put the handle in a horizontal position and the seat is locked in place. I know there were different models that might have different mechanisms - mine is a 5-window. Not that I am using it but I woukd like to know what I have as there is no spring involved.
TomT/Williamsburg is offline   Reply With Quote
Old 05-31-2019, 06:56 AM   #5
DavidG
DavidG's Avatar
TomT/Williamsburg,
All of the '32 adjustable seats are spring assisted, including the standard coupes (5-windows). The photo below shows the assist spring in a standard coupe.
Old 05-31-2019, 09:01 AM   #6
hotrodA
hotrodA's Avatar
That looks similar to the Tudor spring, if not the same. Seems like Henry would use just one if it would serve. Thanks, David.
