Old 12-06-2021, 05:00 AM   #1
Lawson Cox
Lawson Cox's Avatar
Default Parts for 1939 V8 60HP engine for Early Ford V8 Museum
As many of you are aware, I am restoring , at least cosmetically, a V8 60HP engine and transmission which will be donated to the Early Ford V8 Museum in Auburn, Indiana when I pass away. I will be needing some small parts from time to tome, so keep in touch.
At this point I need the clam shell, at least the outer half, the cork seal, the special inner bolt (I have the special thick washer) and the two bolts that hold it together. I will also need the gasket between the transmission and engine.
If you have these parts let me know how much, or it would be nice if you can donate them to the project for the museum.
At my age your prompt attention to this request is greatly appreciated.
Lawson Cox
[email protected]
404-316-7848 cell
770-784-0507 land line
Old 12-06-2021, 10:06 PM   #2
Ken/Alabama
Ken/Alabama's Avatar
Default Re: Parts for 1939 V8 60HP engine for Early Ford V8 Museum
Are they not the same as the 85hp V8??
Ken/Alabama is offline   Reply With Quote
Old 12-07-2021, 03:06 PM   #3
Lawson Cox
Lawson Cox's Avatar
I'm not sure. Are they? My research library is sorely lacking nowadays.
Old 01-05-2022, 10:00 AM   #4
enginepieces
You pm me asking if the cyld heads i had were aluminum. I cant pm yet so i am posting this answer all of my cyld heads are cast iron. I wish you luck in your search.
Enginepieces
enginepieces is offline   Reply With Quote
Old 01-05-2022, 10:16 AM   #5
jimTN
Ujoint housing is same as the 85. Are you looking for a set of alum heads? If so I have a set.
jimTN is offline   Reply With Quote
Old 01-05-2022, 06:36 PM   #6
Lawson Cox
Lawson Cox's Avatar
Yes, Jim. Check your PM's
