08-13-2021, 10:51 PM | #1 |
'60 ford 292 ignition points/ condenser
I have looked hi & low trying to find P/N's for Motorcraft points & condenser.
I've found standard parts and off brands but no Motorcraft. Any info or recommendations if no Motorcraft available -thanks |
08-14-2021, 12:53 AM | #2 |
Re: '60 ford 292 ignition points/ condenser
POINT SET - B8Q 12171-A (DP-12)
- 1957 thru 1974 V8 COND - C9AZ 12300-A (DC-13-A) - 1959 thru 1974 V8 FORGOT - The PN's in parenthesis are MOTORCRAFT and that is how you would SEARCH for them new on the net. Either new or NOS are available - FOMOCO-AUTOLITE-MOTORCRAFT.
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) Last edited by KULTULZ; 08-14-2021 at 07:30 AM. Reason: CRS |
08-14-2021, 04:53 AM | #3 |
I have some N.O.S. Motorcraft and some other N.O.S. U.S.A. made brands....
Always best to simply call me --- Craig --- 516 - 485 - 1935..... |
08-14-2021, 07:32 AM | #4 |
Do you advertise anywhere or have a inventory list available? It would be nice to know what you are hiding up there ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) |
08-14-2021, 10:13 PM | #5 |
every time I checked DP-12 & DC -13-A it comes up with "will not fit your car". Have tried multiple web sites. I thought most ford engines took the same points no matter what(Y-block, SBF, BBF). Actually I bought both last night then got thinking to check with different dealers to see if the ones I ordered were correct. That's when I got confused!
08-15-2021, 06:03 AM | #6 | |
If so, that's them.
08-15-2021, 07:38 AM | #7 |
all v8 points 57 to 74 are same.
