Old 06-04-2018, 07:00 AM   #1
Mike in Mass
Mike in Mass's Avatar
Default could have been worse
I hop'd into my 39 truck yesterday with my wife for a drive up to the hospital to see her sister . "I Got a bad feeling about this " she says . Ya sisters gonna bee fine ! ,,,,, thats not what she meant. Might be the 5 times she flat towed me home last season that has her a little leary. OK ,On the highway cruising at 50,,I get a loud banging ,scraping,,WTF. Still had motor power ,just somthing scaping.made it off the exit, pulled into a parking lot .The main bolt that holds the fan/generater had snapped and was laying against the back of the fan hub .No damage to anything .lucky lucky lucky. My brother thinks it was the belts and maybe the pullies not being perfectly aligned. Anybody ever have somthing like this break on there ol flathead ,seems crazy to.me
Mike in Mass is offline   Reply With Quote
Old 06-04-2018, 07:10 AM   #2
fortyonerag
fortyonerag's Avatar
Default Re: could have been worse
Not my flattie, but I had a fan come apart on an old 52 stovebolt chev once. One blade embedded itself in the radiator, one blade went through the upper radiator hose on its way to leaving an interesting dent in the hood.
It got my full attention at the time I can tell you!
fortyonerag is offline   Reply With Quote
Old 06-04-2018, 07:15 AM   #3
fordwife
Maybe it was overtightened, but my guess is that 70 plus year old bolt just got old and cyrstalized.
fordwife is offline   Reply With Quote
Old 06-04-2018, 07:31 AM   #4
51 MERC-CT
51 MERC-CT's Avatar
Buy the looks of the stud, it has been cranked on with a pipe wrench or something else at one time or another.
Old 06-04-2018, 07:53 AM   #5
Mike in Mass
Im hoping I can get everthing out of the way and weld a nut on the broken bolt- end and back it out. course its probably just as easy to take the intake off and fix or replace . I have plenty of intakes and bolts. I admit, the bolt does look suspect. Im going to wait till the rain stops to take it apart.
Old 06-04-2018, 07:57 AM   #6
51504bat
51504bat's Avatar
I should have one you can have. PM me if you want it.
Old 06-04-2018, 08:11 AM   #7
Ol' Ron
Ol' Ron's Avatar
Good greaf, what doz the rest of the engine look like??
Old 06-04-2018, 08:19 AM   #8
JSeery
JSeery's Avatar
Yep, the bolt looks like it has been under water!
Old 06-04-2018, 08:23 AM   #9
revkev6
well, he does live in plymouth... you know, "plymouth rock", pilgrams, the atlantic ocean
revkev6 is offline   Reply With Quote
Old 06-04-2018, 09:01 AM   #10
Mike in Mass
I cant get pics to load of my motor unless I zoom in ,sorry. Its been running great . ,,,,until it wasnt,,,,
Old 06-04-2018, 09:02 AM   #11
40cpe
40cpe's Avatar
I can tell you from experience that most women don't like being broken down, or out of gas, on the side of the road.
Old 06-04-2018, 09:16 AM   #12
George/Maine
George/Maine's Avatar
That same bolt snapped on Vic Fl few years ago
George/Maine is offline   Reply With Quote
Old 06-04-2018, 09:45 AM   #13
RalphM
RalphM's Avatar
I had one half of the belt sheave completely break off of the hub once. Luckily it didn’t go anywhere, and no harm was done.
RalphM is offline   Reply With Quote
Old 06-04-2018, 10:09 AM   #14
fordwife
If it were me, I would pull the manifold rather than take a chance on welding in your engine compartment.
Old 06-04-2018, 10:28 AM   #15
russcc
Good analysis by Fordwife & 51 Merc. The stud, (not bolt), has been tweaked with something like a pipe wrench maybe because it was stuck in the manifold, and would not come out. That could have caused the stud to crack or crystallize. You were lucky. Ray Helgers explained to me that the lower you keep the generator on the stud, the less stress it puts on the stud and the manifold where they frequently break off. The longer the fan belt, the higher the generator, the more stress. You see a ton of those early aluminum manifolds with a broken front section where the stud mounts.
Old 06-04-2018, 11:42 AM   #16
Mike in Mass
Thanks Guys for the insight and comments .I will switchout the intake .I have a nice replacement . This is the 239 Merc motor from 42.It was in my truck when I got it .Would it have bigger belts ? there not duel pullies but they do seam wide
Old 06-05-2018, 04:12 AM   #17
Karl
Karl's Avatar
Mine was worse. Threw a fan blade and the resulting imbalance broke the inlet manifold and drove the remains of the fan through the radiator -Not pretty or cheap to fix !
Karl is offline   Reply With Quote
Old 06-05-2018, 08:25 AM   #18
Bored&Stroked
Bored&Stroked's Avatar
You are a fortunate man! I'm sure if this happened to me, it would cost me a couple hundred for a new 32 fan, maybe a new magneto and surely a new radiator! I can easily see a couple thousand $$$ - and that is probably optimistic! LOL
Old 06-05-2018, 08:25 AM   #19
Bored&Stroked
Now that sucks big time!
Old 06-05-2018, 04:35 PM   #20
FlatheadTed
FlatheadTed's Avatar
Often we don't know the history of that stud and who wrenched on it ,so fit a bracket to the end down to the manifold Ted
http://www.flatheadted.com
