Go Back   The Ford Barn > The Swap Meet > For Sale > Model-A
Old 10-29-2011, 07:31 PM   #1
OoltewahSpeedShop
OoltewahSpeedShop's Avatar
Default 1931 Ford Tudor Sedan Hot Rod project
City: Ooltewah
State: Tn.
Price: 12,500
1931 Unchopped Tudor sedan. Channeled the width of the frame. Solid South Dakota body with only rust in the very bottom. Full set of Howell's patch panels to fix everything including header panel and visor. 2X3 .125 wall custom built frame, kicked 3" in front and 12" in rear. 9" Ford on 4-link with coilovers. Super Bell 4" dropped front axle with '46 ford dropped wishbones. Pete & Jakes reversed eye spring and shackles. 4-wheel disk brakes. Aluminum radiator w/ chopped-filled original '32 shell and insert. Pete & Jakes '39 style pedals with dual master cyl. and hyd. clutch master and slave cylinder. Set up with 327 and Saginaw 4-speed from '68 Chevelle. Transmission has been totally rebuilt, engine is stock. Corvette bellhousing. (3X2 stuff, Flyrite valve covers and Limefire headers are gone). Reversed Corvair steering box with polished Speedway vintage style steering column and Sprint car steering wheel. Wheel Vintiques black powder coated steel wheels 15X8 rears and 15X4 fronts (smooth center caps) with Radir M&H Cheater slicks (whitewalls turned in) and skinny blackwall bias fronts.
Everything is well built and very safe, no junk. All parts are brand new 0 miles. Freshen the 327, wiring, plumbing, glass, and you could be driving. If you don't want the engine/trans or tires/wheels, I will drop the price accordingly.
Will trade for a RUNNING-DRIVING '28-'48 FORD, Harley or Cafe bike.
The complete build since day one is on the Hamb, on my profile page. Tons of pictures.
Kevin
423.320.4919....cell
Sold, thanks for looking.
OoltewahSpeedShop is offline   Reply With Quote
