09-05-2020, 12:04 PM | #1 |
Starts runs stops
29 Model a pickup has Not been run in a year. It starts runs for a short period then dies. Thinking carb or gas feed. Any ideas or suggestions appreciated. Thanks Pete.
09-05-2020, 12:16 PM | #2 |
Re: Starts runs stops
Remove the drain plug from the carb into a clear jar check for water. Let the fuel flow you should have a good stream, not like a 90 yr old man as stated by a grandson. No fuel or slow stream, remove gas tank cap, clean or replace filters, that's a good start.
09-05-2020, 01:04 PM | #3 |
If gas flow is good , It could be a bad condenser or coil instead . A bad condenser or coil can sometimes work good until it warms up and will then cease to function until it cools a while .
09-06-2020, 04:35 PM | #4 |
