Old 11-15-2018, 09:42 AM   #1
wbs
Default early and late transmission
hello- i have a late trans but is badly rusted--i can get a used early trans, with its shift tower, u joint with its inner and clam shell.
correct me: it looks like i can take all the parts out of early, change shift forks shafts and change inner u joint cap yes or no?
any other advice appreciated
wbs is offline   Reply With Quote
Old 11-15-2018, 02:21 PM   #2
Mike Peters
Mike Peters's Avatar
Default Re: early and late transmission
So you are building a 30-31 transmission? If so, keep in mind that the u joint clamshells between 28-29 have a different bolt pattern than the 30-31 clamshells. So you need to use the appropriate inner flange. Do a trial fit before mounting to the transmission so you know for sure all the bolt holes align. I think the transmission covers for all years interchange, but others will know more about that then me.
Mike Peters is offline   Reply With Quote
Old 11-15-2018, 07:22 PM   #3
wbs
thank you.,will do
