Old 11-04-2018, 11:37 AM   #1
walkerlakeprinter
walkerlakeprinter's Avatar
Default Double Nutting advice
I am trying to remove the water pump studs to replace with the clever new bolts. The first one I tried double nutting and it came off without a fuss. The next two I tried just turned both nuts and did not budge the stud. Is there a secret to double nutting so that when backing off the inner nut that both nuts don't turn? I bought a stud puller, but when it failed to move the first stud and scored up the threads that I might have had to use if my removal job failed, I decided to try the double nutting. I followed the advise about heating the studs, tapping with a hammer and then using PB Blaster overnight.
walkerlakeprinter is offline   Reply With Quote
Old 11-04-2018, 12:40 PM   #2
Phil Brown
Phil Brown's Avatar
Default Re: Double Nutting advice
Heat
Phil Brown is offline   Reply With Quote
Old 11-04-2018, 01:12 PM   #3
Kahuna
Kahuna's Avatar
Heat X 2
Kahuna is offline   Reply With Quote
Old 11-04-2018, 02:58 PM   #4
Patrick L.
Patrick L.'s Avatar
Well, you did what you needed to do. Heat, tapping, repeat. When double nutting, you really need to crank down on the two nuts and get them just as tight as you can. Sometimes thats not enough. Stuff happens.
Old 11-04-2018, 03:12 PM   #5
J Franklin
J Franklin's Avatar
Add to the mix some good penetrating oil. Or heat and wax.
Old 11-04-2018, 07:45 PM   #6
Big hammer
Use two newer nuts, I've found that if I use the same nuts they may not work !?
get a bigger hammer tap done
Old 11-04-2018, 08:18 PM   #7
1crosscut
1crosscut's Avatar
When using heat on stubborn studs I aim to get as much heat into the stud as possible without heating the block/area around the stud. Then take a very wet cloth and cool the stud as quickly as possible. Doing this a few time has worked well for me. Just be careful not to get a steam burn.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 11-04-2018, 08:43 PM   #8
holdover
if it has to come out and everything else fails, and you plan on replacing the stud, double nut it and ARC weld the stud to the top nut. This after Kroil, PB Blaster, wax, heat etc, AND A LOT OF PATIENCE. Good luck, been there and done that
holdover is offline   Reply With Quote
Old 11-04-2018, 10:08 PM   #9
daveymc29
daveymc29's Avatar
Arc welding the outer nut will put a lot of heat on the stud and it should then back out.
daveymc29 is offline   Reply With Quote
Old 11-04-2018, 11:02 PM   #10
Mike V. Florida
Mike V. Florida's Avatar
Keep in mind one of the studs actually enters the water jacket and could be really rusted in place.
Old 11-05-2018, 10:06 AM   #11
54vicky
54vicky's Avatar
I have used a lock washer between the 2 nuts it helps to lock them better.no pun intended
54vicky is offline   Reply With Quote
Old 11-05-2018, 10:31 AM   #12
katy
katy's Avatar
Good tip, thanks.
Old 11-05-2018, 11:17 AM   #13
Floats
Floats's Avatar
Katy,
Try putting pressure in both direction, alternate a little tighter, a little back until you have broken the lock then go back and forth until loose.
Regards
Chris
Floats is offline   Reply With Quote
Old 11-05-2018, 12:56 PM   #14
walkerlakeprinter
THANKS ALL!!! I tried some of all the above suggestions. My last try with heating, then cooling rapidly with a wet cloth, followed by running a die down on the stud to extend the threads closer to the block so that I had room to put a lock washer between the two nuts did the trick. Thanks again, to all of you!
Old 11-05-2018, 07:37 PM   #15
1crosscut
1crosscut's Avatar
Glad you were able to get them out.
Old 11-07-2018, 02:27 AM   #16
Hoogah
Hoogah's Avatar
Which one? That would be the one I’d try first.
Hoogah is offline   Reply With Quote
Old 11-07-2018, 10:49 AM   #17
Randy(PA)
To answer your original question, yes, there is a secret to double-nutting, and that is to tighten the nuts against each other so that there is tension between them. That is done by putting a wrench on each nut and turning the lower nut up against the upper (or front) nut. Do not just tighten one and then tighten the other down against it. The object is put tension in the stud between the nuts.
Randy(PA) is offline   Reply With Quote
Old 11-07-2018, 10:18 PM   #18
walkerlakeprinter
The upper left stud is open to the water jacket. The rest are in blind holes.
Old 11-09-2018, 01:10 PM   #19
DHZIEMAN
Removing stubborn studs is always an issue. Double nutting comments are good and heating is usually needed on stubborn studs but so is patience! Sometimes lots of patience and heat and hammer tapping will do the job to break loose these stubborn devils but then again sometimes something bad happens and then the job really gets into "easyout territory! Hope that does not happen!
DHZIEMAN is offline   Reply With Quote
