03-25-2020, 06:32 PM | #1 |
Flathead V8 radiator
Two upper hose brass connections, sweated onto the brass upper tank.
One of them looks like the photo. Weep/seep..... whatever you want to call it. I'm having to top the radiator off after every drive. (Whether the water level is above or below the fitting, same result) I'm assuming the water level needs to be at or slightly above the top of the core. My gut reaction is I should try to re-solder the problem fitting. Water temp may get to a blistering 165-degrees at the maximum. No water in the oil pan, no water out the exhaust and none on the ground. Water is going somewhere. Could I be losing 1 quart of water out the leaking seam at the connector? It isn't visibly "wet." You can see the evidence though. Anyone ever solder something like this radiator fitting? (acid core solder) Historically, my past results haven't been too impressive. I may try it anyway as I loath taking the radiator out of this vehicle and then having to re-establish the water level after you reinstall..... which seems to take about 2 months. |
03-25-2020, 06:40 PM | #2 |
Re: Flathead V8 radiator
Have you considered an epoxy sealer alternative to soldering? Is that even practical? Not a lot of pressure....4lbs?
03-25-2020, 06:47 PM | #3 |
Maybe take out the radiator go to a shop and have it serviced anyway that way it will be soldered up again . After that arrange with them to come back and have it pressure tested and see if you have a leak elsewhere. Of course mind how much pressure they put in . And if I where you Id put in 180 thermostats.
03-25-2020, 11:17 PM | #4 |
Don't even think about some high school kid fix. Nothing short of a professional job done at a real radiator shop will do.
Alan |
03-25-2020, 11:41 PM | #5 |
F-1 - Rick does outstanding work and he is over in Azusa.
http://www.classicautoradiator.com/ Ricks Radiator 693 E Arrow Hwy, Azusa, CA 91702 Phone: (626) 967-7518
Henry Ford designed the flathead without the aid of a computer. |
03-26-2020, 01:55 AM | #6 |
If itīs a crack due to fatigue in the metal then itīs a different story.. |
03-26-2020, 03:18 AM | #7 |
It looks like a fatigue crack heading up towards the centre of the tank.
I just soldered a repair on my 33 tank where it had cracked. I used a section of copper pipe and split it out to make a small sheet. I soldered it over the crack and made what I would consider to be a good repair. If you want to try soldering it, don't try and do it with the rad in place. Take it off and clean it meticulously. A wire wheel in a drill works good. Abrasive paper and wire wool is good too. Lay the rad down so the area to be soldered is horizontal. Cut your patches. Clean everything to bright metal. Put solder on the radiator and then put the patch over and heat it until the solder melts and the two fuse together. Then carefully apply solder around the edge to make sure. Use lots of flux before and during the job. I did take some video of my repair but it will not be ready to put on youtube for a while yet. I took my rad from having multiple leaks to holding water nicely. If your repair does not work, two minutes at a radiator shop will have your failed repair melted off there and they can have a go. In other words you won't screw it up for them by having a go first. Mart. |
03-26-2020, 03:21 AM | #8 |
the trick will be getting rid of the crud that has accumulated in the seam by crud i mean coolant and calcium etc with out doing that your wasting your time . Find a good rad shop and let them work their magic it pays in the long run. By the look of that photo that neck isnt far from total failure and you can bet it wont happen in your driveway
03-26-2020, 04:26 AM | #9 |
If you are going to solder it...rivets has to come out to be able clean both sides.
Stainless wirebrush !! any leftovers from sandpapers or other abrasive will work against you. Solder water(flux) in bottle and a brush. Low temp solder made for radiators...if you try using hightemp for plumbing there is a fair chance you melt another place and create more leaks. Rose bud tip in an Oxy/Acethylene torch. |
03-26-2020, 11:37 PM | #10 |
Rose Bud tip!
That’s about like using a bon fire to cook a marshmallow! A bit too much heat for a radiator. A smaller brazing tip will work just fine. |
03-27-2020, 12:20 AM | #11 |
03-27-2020, 02:35 AM | #12 |
I used to use a oxy acetylene flame but very gentle. I recently used a very simple el cheapo blowtorch. Nothing fancy.
My technique is to be ready to flick the flame away the moment I feel it is getting too hot. Flick it away.. Bring it back..Flick it away.. etc. Like most things I am self taught so I may be doing it different to others. Maybe completely wrong, but I normally manage to make the repair. Mart. |
03-27-2020, 03:50 PM | #13 |
I chased the same issue. I think the aging tanks fatigue cuz the engine vibration is transmitted thru the hose & pipe.
I had work done at a shop and he found and soldered up the fatigued areas as well as rodding.
Tim Downtown, Ca |
03-27-2020, 04:24 PM | #14 | |
I'll probably end up taking it out and on down to Rick's Radiator. Not looking forward to either part of the R&R. |
03-27-2020, 04:46 PM | #15 |
03-27-2020, 07:10 PM | #16 |
Maybe try the really cheap fix, before going to all that trouble. May be possible to do with the radiator in the car.
My radiator was showing some light calcium deposits around the joints of top hose connectors to top tank, and tank to core edge. Wire brushed the heck out of the whole top tank, brushed on a thin layer of FlexSeal ("As Seen on TV"}. Let the FlexSeal set up for two days and then painted the top tank black. After about a year and 2,000 miles with a 7 lb cap, no leaks or signs of failure of the FlexSeal. Radiator FlexSeal small.jpg Radiator Calcified small.jpg |
