Has any one used any of the aftermarket clutch/brake pedal assembly's on a model A such as TCI,Chassis engineering or Brookville Roadster etc.? If so which ones have been the easiest for placement? Installing an S10 5 speed. I also need one that the bolt is the pivot,not with a stationary welded in pivot as I will not be able to slide the pedal arm sideways off the shaft. I need to be able to put the pedal arm in place then install the pivot. This car also has an aftermarket firewall that also takes up floor room.
