Old 01-23-2014, 12:34 AM   #1
clay co 27
Default engine block checker
I ordered a motor block crack detecter from Snyders and received it today.
It works on air pressure, has anyone used these and do they work, thanks
clay co 27 is offline   Reply With Quote
Old 01-23-2014, 01:12 AM   #2
Mark in MT
Default Re: engine block checker
They work good, I use it in combination with a manga flux test to make sure that I am working on a good block. I wound use it after cleaning the block, as crud in the water jackets may seal a crack, giving a false sense of security.
I found a defect in one block that other wise would have been missed. Somebody in the past had broken a bolt off in the back of the block, in the process of drilling it out, they drilled thru into the water jacket.
Mark in MT
Always looking for another opportunity to be wrong.
Mark in MT is offline   Reply With Quote
