01-21-2014, 02:02 AM | #1 |
6 volt charging 12 volt battery
How can you make a 6 volt model a generator charge a 12 volt battery?
I am not changing to 12 volts, just wondering how it can be done. |
01-21-2014, 07:35 AM | #2 |
Re: 6 volt charging 12 volt battery
If your gen is a 3 brush it will charge 12 volts. First install 12 volt battery then Just adjust the 3 rd brush to amps you need. I go around 8 amps for most daytime use . if you set it too high you will burn up gen. DONT FORGET TO CHANGE BULBS
also this will work + or - ground |
01-23-2014, 12:46 AM | #3 |
whizzernick, thanks a lot for the information.
01-23-2014, 01:01 AM | #4 |
