Old 10-06-2015, 02:09 PM   #21
CarlG
CarlG's Avatar
Default Re: Frame Number For Registration
Originally Posted by Fred K-OR View Post
I had a tag made up that says "vin number" on it and I fixed it to the fire wall under the hood. I did this because I changed the engine in the coupe and that engine number was the vin number on the title. I am hoping that the next time I change the title, if I do, that tag will work. May have to go to a couple different DMV offices.
I am sure that is what I am going to have to do when I get my new engine. Do you have a picture showing how you did this?
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 10-06-2015, 02:22 PM   #22
Charlie Stephens
Following Fred's path in my opinion will probably get you in trouble in the long run. Call your states DMV, they will probably install a VIN tag on the door jamb. Just be sure to do it before you remove the engine with the serial number that matches the paperwork.
Charlie Stephens
Old 10-06-2015, 03:48 PM   #23
Willie Krash
Willie Krash's Avatar
Fred the Oregon State Police (OSP) will issue a tag and put it in your door jam. I'm not sure they even charge for it. I went over to the OSP office and requested it. I was told to go to the DMV and they will make the appointment for me.
They even offered me the Troopers phone number as I protested going to the DMV to do what we could do at the OSP office.
Once you are tagged the engine et.al doesn't matter.
Mike Stitt
"A business that make nothing but money is a poor business."
-Henry Ford
Willie Krash is offline   Reply With Quote
Old 10-06-2015, 05:35 PM   #24
mshmodela
mshmodela's Avatar
Having have to learn some of the OHIO code myself.. (Don't asK Here's OHIO law on VIN
Chapter 4501:1-11 Replacement of Vehicle Identification
http://codes.ohio.gov/oac/4501%3A1-11
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 10-06-2015, 05:53 PM   #25
100IH
You might consider lifting the body and removing the LH splash apron before the inspection to avoid any surprises. Good to know what they are going to find at the inspection!! Henry said history is bunk.
100IH is offline   Reply With Quote
Old 10-06-2015, 08:04 PM   #26
burner31
burner31's Avatar
The number is stamped on the floor rail on the drivers side of my '31 SW town sedan.
That may be a good place to "re-stamp" your number.
Just pull back the carpeting to show them.
Hint: make it look aged
Keith
Shawnee OK
'31 SW 160-B
Old 10-06-2015, 08:32 PM   #27
pcup
Here in co. They have emissions testing business's that also verify vin for a small fee.[$20] that's what i did 2 months ago, as they [dmv] wouldn't accept the existing titles from ca.good luck, pcup
pcup is offline   Reply With Quote
Old 10-07-2015, 08:49 AM   #28
31pickup650
31pickup650's Avatar
I am just trying to avoid having to pull the body off. The last thing I want to have is have issues with stubborn bolts and finally et it off to find that the number on there still doesn't match.
-Noah
1931 Model A Pickup
My Model A : https://www.fordbarn.com/forum/showthread.php?t=173024
31pickup650 is offline   Reply With Quote
Old 10-07-2015, 08:49 AM   #29
31pickup650
I will read over this to see what I can learn. Thanks.
-Noah
1931 Model A Pickup
Old 10-07-2015, 01:34 PM   #30
Fred K-OR
Fred K-OR's Avatar
Yes maybe I should have had the DMV put a tag on the door jam of my coupe. They did do that on my huckster when I got it registered. But the huckster was a "build" from an old CCPU.
If I have to, guess I could haul the old engine in with the rig and show them both. But on the other hand, if I keep the coupe long enough, then I can let my kids worry about getting a "certified" title.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 10-07-2015, 06:04 PM   #31
31pickup650
Good news guys! Turns out the original VIN is on the spare motor. I will have to figure out if a picture of if is sufficient for the DMV or what, but problem solved (theoretically). Thanks for the help guys. I'll update when I get it registered.
-Noah
1931 Model A Pickup
Old 10-07-2015, 06:40 PM   #32
mshmodela
mshmodela's Avatar
Great! PM sent..
-Mike
Cleveland, Ohio
Old 10-07-2015, 09:23 PM   #33
Tom Wesenberg
Tom Wesenberg's Avatar
I pressed a piece of white paper into the number, then used a pencil to make a pencil etching of the number. This satisfied the DMV in my state. I took a picture as well just to be safe.
Old 10-08-2015, 06:20 AM   #34
31pickup650
Default Frame Number For Registration
Thanks Tom. I will call the dmv today and ask if that will work. The etching might be a good way to prove I actually have the engine in my possession.
-Noah
1931 Model A Pickup
Old 10-08-2015, 08:50 AM   #35
pgerhardt
pgerhardt's Avatar
Couldn't you just use a flappy sander on you're angle grinder to grind off the wrong number, restamp the correct number on the engine, and repaint the area Ford green?
pgerhardt is offline   Reply With Quote
Old 10-08-2015, 09:33 AM   #36
31pickup650
I suppose I could. I should be fine now since I have the engine with the correct VIN.
-Noah
1931 Model A Pickup
Old 10-12-2015, 12:26 AM   #37
lnvmyrick
lnvmyrick's Avatar
I have a 31 RPU in California...just finished with DMV and highway patrol. I ended up "lifting the body enough to access the frame #. Mine was rusted away too far to reuse. The highway patrol officer added a Reg. number tag on the frame crossover just behind the battery for easy future access. can't be seen without removing the battery access floorboard plate.
lnvmyrick is offline   Reply With Quote
Old 10-16-2015, 12:44 AM   #38
Mike V. Florida
Mike V. Florida's Avatar
Illegal, but it's done all the time.
Old 10-16-2015, 07:00 PM   #39
1931 flamingo
1931 flamingo's Avatar
JMO< but the DMV tag lowers the value of the vehicle.
Paul in CT
Old 10-16-2015, 07:33 PM   #40
Brentwood Bob
I would personally want to know what the frame s/n is on any vehicle I own, or want to own.
Eventually I believe all problems have to be faced.
But, evidentlly I am unique.
Bob
Brentwood Bob is offline   Reply With Quote
