10-06-2015, 02:09 PM | #21 | |
Re: Frame Number For Registration
10-06-2015, 02:22 PM | #22 | |
Charlie Stephens |
10-06-2015, 03:48 PM | #23 | |
They even offered me the Troopers phone number as I protested going to the DMV to do what we could do at the OSP office. Once you are tagged the engine et.al doesn't matter.
Mike Stitt "A business that make nothing but money is a poor business." -Henry Ford |
10-06-2015, 05:35 PM | #24 |
Having have to learn some of the OHIO code myself.. (Don't asK Here's OHIO law on VIN
Chapter 4501:1-11 Replacement of Vehicle Identification http://codes.ohio.gov/oac/4501%3A1-11
-Mike Late 31' Ford Model A Tudor, Miss Daisy I don't work on cars --I'm learning about my Model A. Cleveland, Ohio |
10-06-2015, 05:53 PM | #25 |
You might consider lifting the body and removing the LH splash apron before the inspection to avoid any surprises. Good to know what they are going to find at the inspection!! Henry said history is bunk.
10-06-2015, 08:04 PM | #26 |
That may be a good place to "re-stamp" your number. Just pull back the carpeting to show them. Hint: make it look aged
10-06-2015, 08:32 PM | #27 |
Here in co. They have emissions testing business's that also verify vin for a small fee.[$20] that's what i did 2 months ago, as they [dmv] wouldn't accept the existing titles from ca.good luck, pcup
10-07-2015, 08:49 AM | #28 |
I am just trying to avoid having to pull the body off. The last thing I want to have is have issues with stubborn bolts and finally et it off to find that the number on there still doesn't match.
-Noah 1931 Model A Pickup My Model A : https://www.fordbarn.com/forum/showthread.php?t=173024 |
10-07-2015, 08:49 AM | #29 | |
I will read over this to see what I can learn. Thanks. Sent from my iPhone using Tapatalk
10-07-2015, 01:34 PM | #30 | |
If I have to, guess I could haul the old engine in with the rig and show them both. But on the other hand, if I keep the coupe long enough, then I can let my kids worry about getting a "certified" title.
10-07-2015, 06:04 PM | #31 |
Good news guys! Turns out the original VIN is on the spare motor. I will have to figure out if a picture of if is sufficient for the DMV or what, but problem solved (theoretically). Thanks for the help guys. I'll update when I get it registered.
10-07-2015, 06:40 PM | #32 |
Great! PM sent..
10-07-2015, 09:23 PM | #33 | |
10-08-2015, 06:20 AM | #34 | |
Thanks Tom. I will call the dmv today and ask if that will work. The etching might be a good way to prove I actually have the engine in my possession. Sent from my iPhone using Tapatalk
10-08-2015, 08:50 AM | #35 |
Couldn't you just use a flappy sander on you're angle grinder to grind off the wrong number, restamp the correct number on the engine, and repaint the area Ford green?
10-08-2015, 09:33 AM | #36 |
I suppose I could. I should be fine now since I have the engine with the correct VIN.
10-12-2015, 12:26 AM | #37 |
I have a 31 RPU in California...just finished with DMV and highway patrol. I ended up "lifting the body enough to access the frame #. Mine was rusted away too far to reuse. The highway patrol officer added a Reg. number tag on the frame crossover just behind the battery for easy future access. can't be seen without removing the battery access floorboard plate.
10-16-2015, 12:44 AM | #38 |
Illegal, but it's done all the time.
10-16-2015, 07:00 PM | #39 |
JMO< but the DMV tag lowers the value of the vehicle.
Paul in CT |
10-16-2015, 07:33 PM | #40 |
I would personally want to know what the frame s/n is on any vehicle I own, or want to own.
Eventually I believe all problems have to be faced. But, evidentlly I am unique. Bob |
