Old 05-07-2021, 07:56 AM   #1
Mart
Mart's Avatar
Default Mart's Update 2021 Episode 19 Part 1&2: The 32 Sedan body goes on!
Hello welcome to Mart's Garage.
Part 1:
In this episode I Get the 32 Sedan body out from where it was stored and down onto the chassis. It looked a bit sketchy and it was. It's amazing how putting the body on changes the appearance completely.
https://youtu.be/8YbTwzEcCnA
Part 2:
In this episode I end up doing something completely different to what I started out doing.
I get the body bolted on and fulfil my OE hardware fixation.
https://youtu.be/sK_lgkMiDvM
Thanks for following along.
Mart.
Old 05-07-2021, 10:38 AM   #2
Krylon32
Default Re: Mart's Update 2021 Episode 19 Part 1&2: The 32 Sedan body goes on!
Great job doing it alone. Looks good. I don't think there's any of us who have done this for a long time haven't had that heart stopping moment when the body does a little shift as we were installing it. Also most of us have worked in a small space like yours.
Krylon32 is online now   Reply With Quote
Old 05-07-2021, 01:54 PM   #3
mfagan
mfagan's Avatar
Great job. I’m amazed at all you get done unassisted!
Marvin Fagan
214-697-8430
mfagan is offline   Reply With Quote
Old 05-07-2021, 02:36 PM   #4
DavidG
DavidG's Avatar
Mart,
I very much enjoyed your video regarding body-to-frame hardware, but the last body-to-frame attachment did not use a hard spacer originally, but rather a 1/4" thick rubber pad on each side. Similarly, the penultimate body-to-frame attachment had a 1/8" thick rubber pad on each side between the body and the chassis frame. If you use metal spacers, you run the risk of fractures showing up along the seams between the body's back panel and the quarter panels, especially since your goal is to drive the car extensively and if your car does not have a late frame with the inner reinforcements to the side rails at the rear cross member.
Old 05-07-2021, 05:20 PM   #5
Mart
Mart's Avatar
Thanks Fellas.
David, all points noted. This body had fatigue all around that area (where the light brown primer is). I think there was a remnant of the rubber pad in that tub o bolts. I will look for a suitable substitute and make the swap. This frame was badly broken over the axle. It had no extra strengthening of any sort, other than the doublers where the shock absorbers bolt on.
It great having the real experts looking over your shoulder. Thanks.
Old 05-08-2021, 12:41 AM   #6
Will D
Will D's Avatar
Originally Posted by Mart View Post
I will look for a suitable substitute and make the swap. .
Do you have any old tires kickin' around you could cut a piece out of the side wall?
Sometimes, ingenuity gets in the way of sense and sanity.
Will D is offline   Reply With Quote
Old 05-08-2021, 07:00 AM   #7
mfirth
Hook up some lights & take us for a ride....after i rest. Watching you move stuff alone gave me a back ache, L O L. Thanks Mart !! Cheers !
mike
mfirth is offline   Reply With Quote
Old 05-08-2021, 08:44 AM   #8
41ford1
41ford1's Avatar
Good job getting all of that done alone. I don't know if I would have been as fussy about the hardware as you were. I agree with mfirth. Take us for a ride.
You are never to old to enjoy your childhood.
Forty1fordpickup on the HAMB.
41ford1 is offline   Reply With Quote
Old 05-08-2021, 09:33 AM   #9
deuce5wndw
deuce5wndw's Avatar
Looking good!!!! I really like the wide fives also!
deuce5wndw is offline   Reply With Quote
Old 05-09-2021, 08:36 AM   #10
Brendan
Brendan's Avatar
YES i want to go for a ride! i that it was Kool when we went for a ride with the crusty flatty in the 40 pickup
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
Old 05-09-2021, 11:56 AM   #11
Mart
Mart's Avatar
Thanks fellas, and don't worry, when the time comes it'll be all aboard the Skylark!
Old 05-12-2021, 10:31 AM   #12
Als48
So, the 32 has a name? Skylark?
Als48 is offline   Reply With Quote
