Old 09-16-2019, 02:49 PM   #1
Habusailor
Habusailor's Avatar
Default Head bolt washers
On a 1935 with cast iron heads should there be washers under the nuts?
Habusailor is offline   Reply With Quote
Old 09-16-2019, 02:57 PM   #2
19Fordy
19Fordy's Avatar
Default Re: Head bolt washers
In my 1938-41 Chassis Parts List the pictorial shows a washer along with the stud and nut. However, in the pictorial, there is no separate part # given for the washer. Given the choice, I would use a washer. More astute folks will provide best answer.
Old 09-16-2019, 04:14 PM   #3
51 MERC-CT
51 MERC-CT's Avatar
According to Green book, 21 stud 33-37 uses (351428-S7) washer on Aluminum heads only.
Old 09-16-2019, 05:15 PM   #4
Kube
Kube's Avatar
Only when installing aluminum heads were washers incorporated. No need when utilizing iron heads.
Old 09-17-2019, 07:09 PM   #5
Don Rogers
Don Rogers's Avatar
1935 and 1936 Chassis parts books show (42) 351428-S-7 washers used on both alum. and cast iron heads. Washers may have been eliminated in later years on cast iron heads.
Don Rogers is offline   Reply With Quote
Old 09-17-2019, 08:11 PM   #6
35fordtn
35fordtn's Avatar
Don, The washer does not appear in the Earliest of 1940 Parts catalogs, however the 1934-38 catalogs list it (I do not have a 1933 or 1939) in the Canadian 1938 catalog it states the washer was used on Models: 40,48,50,51,67,68,77,78,79,81A,81C,81T
This certainly supports assumption they were used on iron heads from 1935-38.
35fordtn is offline   Reply With Quote
Old 09-18-2019, 06:28 AM   #7
GOSFAST
GOSFAST's Avatar
If you decide on using washers (very good idea on either iron or aluminum heads) we have available "special" ones that are barely visible under the nuts or bolt heads!
Thanks, Gary in N.Y.
P.S. Here's a shot of them with some OEM bolts, you can see they would almost be "invisible", but they do work!
File Type: jpg Head Bolts OEM Factory-Custom Washers.jpg (39.3 KB, 61 views)
GOSFAST is offline   Reply With Quote
Old 09-18-2019, 07:35 AM   #8
34PKUP
34PKUP's Avatar
I have used (military spec) MS20002-7 flat washers in the past.
At the time they were about 10¢ each.
34PKUP is offline   Reply With Quote
Old 09-18-2019, 08:59 AM   #9
outlaw
Gary, Do you offer these in stainless & will they work with acorn covers? Thank you. Bill
outlaw is offline   Reply With Quote
Old 09-18-2019, 09:52 AM   #10
GOSFAST
GOSFAST's Avatar
Hi Bill, those "black" washers in the photo fit under the chrome acorn nut covers we have on the shelf here.
The O.D. on the washers is .675". May be difficult to see clearly but the photo below shows the entire washer sitting inside the chrome nut!
P.S. Not sure if ARP has them in stainless in the same size, I doubt it though? Will give them a call later in the day, they're out on the west coast, and report back!
Old 09-18-2019, 12:35 PM   #11
outlaw
Gary, Thank you. The black will be fine when I get to that point. I was concerned with the covers not hiding the washers.
Old 09-18-2019, 03:28 PM   #12
flatjack9
flatjack9's Avatar
You can get ss AN flat washers in .745 OD for .06 each.
Old 09-18-2019, 03:49 PM   #13
Fordors
Would you mind posting the source for those, I'd be interested in a reliable vendor for SS hardware.
My school colors are black and blue, I attended the School of Hard Knocks where I received a Masters Degree in Chronic Mopery.
Fordors is offline   Reply With Quote
Old 09-18-2019, 03:59 PM   #14
51 MERC-CT
51 MERC-CT's Avatar
Aircraft spruce--- AN960C76 10¢ each
https://www.aircraftspruce.com/menus/ha/washers.html
Old 09-18-2019, 09:34 PM   #15
flatjack9
flatjack9's Avatar
Check out a post by Tim Ayers above about source of ARP bolts - Allens fasteners. They list all kinds of stuff.
Old 09-18-2019, 10:08 PM   #16
Don Rogers
Don Rogers's Avatar
Getting back to the original question.....Here is the correct washer used in the 1935-36 time frame.
Old 09-19-2019, 07:54 AM   #17
JWL
I have never(to the best of my memory) disassembled a 35-36 iron head engine which had flat washers.
JWL is offline   Reply With Quote
Old 09-19-2019, 08:18 AM   #18
GOSFAST
GOSFAST's Avatar
To answer many of the above posts about the washer availability, the O.P. wanted the washers to fit completely under the acorn nuts, the largest O.D. to fit that number is the size I posted in my original post, .675", anything larger will NOT go!
P.S. ARP doesn't make them in the necessary size in stainless, only the "block-ox" ones. Their smallest O.D. for the stainless 7/16" washers is .812", these will not go with the acorns! They are also 120" thick. The ones we do have here for 7/16" bolts/studs with the correct O.D. (.675") come in either .062" or .120" thick.
Old 09-19-2019, 08:42 AM   #19
flatjack9
flatjack9's Avatar
The OP wanted to know if washers were used on 1935 cast iron heads.
Old 09-19-2019, 10:06 AM   #20
GOSFAST
GOSFAST's Avatar
Hi Jack, he did ask in post #9 about the washers and the nut covers!
P.S. Not really sure you'll find any stainless washers the needed size, 7/16" I.D. by .675" O.D. We use our black ones for rod bolt washers! If you search for 7/16" rod bolt washers you may find them in stainless, I just don't know!
