Old 12-31-2017, 01:42 PM   #1
hardtimes
hardtimes's Avatar
Default thread renovation ?
I'm working with antique aluminum parts, removing brass plugs frozen with time 80+ yrs time. Feeling lucky to have removed some parts, so far, without breaking any casting. Aluminum oxide has made the bond and has indicated that the aluminum threads should be cleaned.
If I do not have right sized taps for the, too large hole, do you know of any way to clean these alum threads without damage ? I will put some lube on reassembly to help prevent recurring problem.
Old 12-31-2017, 01:46 PM   #2
cas3
Default Re: thread renovation ?
you get a bolt that same size and cut some slices in it with the whizz wheel. you have now made a thread chaser!
Old 12-31-2017, 01:57 PM   #3
hardtimes
hardtimes's Avatar
Great idea, I'll think on that one and look for bolt !
Also, wondering will any 'chemical' dissolve the oxide and not harm thread ?
Old 12-31-2017, 05:57 PM   #4
glennpm
glennpm's Avatar
Good idea that cas3 has. I have one of these kits which is hardened steel that is configured the same as he mentioned. This kit works very well!
http://www.sears.com/craftsman-48-pc...p-00942275000P
Old 12-31-2017, 06:35 PM   #5
19Fordy
19Fordy's Avatar
Here's a whole bunch of ideas on how to remove aluminum oxide without
damaging the aluminum.
https://www.google.com/search?ei=OXN....0.aRtxl_zyFL0
Old 12-31-2017, 06:57 PM   #6
rotorwrench
rotorwrench's Avatar
If they are US nation pipe thread, you could get NPT taps for most sizes. If they are bolt thread national fine or course, the thread chasers will work or an old bolt with some flutes cut into it. Steel wire brushes like the ones used to clean battery terminals may also work. It just depends on what size they are.
Old 01-01-2018, 02:17 PM   #7
grumppyoldman
grumppyoldman's Avatar
If the hole's are already too large, you can repair them with a Helicoil kit. They are sold at most auto part's stores. you tap the hole with a special tap and install the helicoil for the proper size bolt. Al
grumppyoldman is offline   Reply With Quote
Old 01-01-2018, 05:29 PM   #8
hardtimes
hardtimes's Avatar
Oooh, that will work, thanks for that !
