08-24-2012, 02:26 PM | #1 |
4 Blade fan hits radiator.
I did a search but couldn't come up with an answer.
I've recently installed a 4 blade fan on my 30' Model A after seeing a major crack on my original 2 blade. Installed, the fan hits the radiator.. I am at a loss, Is there a way to bring the radiator forward? Or bring the fan back?
U.F.R.A ~ United Flathead Racing Association PM For Info! |
08-24-2012, 02:47 PM | #2 |
Re: 4 Blade fan hits radiator.
If this is a new 4 blade fan having a cast iron hub and pressed steel blades held together by 4 bolts I wouldn't fit that either!!!
I have had one of those fly apart and take out the radiator and the water pump Best bet to use a cast ally or plastic blade one John Cochran |
08-24-2012, 02:58 PM | #3 |
It's a NOS original 4 blade, not a recast. This one is riveted together
08-24-2012, 04:22 PM | #4 |
Go back to a 2 blade! lol Serioulsy though, I love my new aluminum 2 blade. For around $40 you can't beat it. And it looks like it belongs to boot!
Good Luck whatever you decide, D Lazaris.
Wanted: Simmons Super Power Head Craig Likon 1931 150B |
08-24-2012, 05:13 PM | #5 |
Hits at the bottom? Hits at the waterpump shaft?
Oklahoma City Model A Restorers Group. |
08-24-2012, 06:38 PM | #6 |
08-24-2012, 07:17 PM | #7 |
Are the blades bent forward?
08-24-2012, 07:33 PM | #8 |
I had that happen and it turned out that the keyway hole had broken and was allowing the fan blade to wobble which allowed the fan to "hit" against a part of the radiator as the blade rotated.
08-24-2012, 08:52 PM | #9 |
I had to try a few fans to find one with the right pitch an size to clear everything
08-24-2012, 09:51 PM | #10 |
Does your hand crank line up properly if you try to crank the car?
Charlie Stephens |
08-25-2012, 12:15 AM | #11 |
I worked on a 39 Ford with that problem. Turns out the fan was for a truck, and the blades were longer than one for a car, so they hit the lower radiator core.
ever try to replace a water pump equipped with a 4 blade?? the radiator has to come out. With a 2 blade, it does not. The advantages of a 2 blade out number the 4 blade in performance, fit, appearance, and cost. |
08-25-2012, 07:52 AM | #12 |
Try loosening the radiator mounting bolts and move the rad forward at the bottom?? Are the blade lengths the same on the 4 blade as the two blade?? Fan "seated" on the w/pump shaft??
Paul in CT |
