Go Back   The Ford Barn > The Swap Meet > For Sale > Model-A
Old 11-12-2019, 02:22 PM   #1
frank55a
Default For Sale - Four (4) Original 1928 Headlight Lenses
City: Wilmington
State: DE
Price: See Ad
These are the second style fluted lenses with the ford script at the bottom of the lens. Per the MARC/MAFCA Restoration Guidelines and Judging Standards these were used from December 27 thru January 1929. All lenses have a raised oval with a raised H under the raised Ford script. Visually when installed the fluted area and Ford oval look the same. Markings are noted below.
Lens #3: Part # A-13060; the H is the same as lenses 4, & 5; has no number at the bottom; manufacture mark is MCK. This lens has a very small chip in the ring on the left side near the bottom.
Lens #4: Part # A-13060; the H is the same as lenses 3, & 5; has a number 4R 174 at the bottom; manufacture mark is L.E.S. This lens has a very small chip in the ring on the right side near the top.
Lens #5: Part # A-13060; the H is the same as lenses 3, & 4; has a number 3R 217 at the bottom; manufacture mark is L.E.S. This lens has a few light scratches on the fluted surface which should be able to be easily polished out.
Lens #6: Part # A-13060; the H is slightly smaller than lenses 3, 4, & 5; as you can see there are 2 large chips on the top and bottom which removed the manufacture's mark, these chips are not visible when the lens is installed. $10 for this lens when purchasing 1 or 2 other lenses. Lens #6 is FREE when
purchasing all 3 of the other lenses.
$30 each or $50 for a pair or $75 for all 4 lenses, plus shipping, USA buyers only. No Pay-Pal, moneyorders only.
Contact Frank at [email protected]
frank55a is offline   Reply With Quote
Old 07-02-2020, 07:49 AM   #2
frank55a
Default Re: For Sale - Four (4) Original 1928 Headlight Lenses
Sold
