10-02-2019, 03:07 PM | #1 |
31 Front spring shackles, how tight or lose?
Last winter I replaced my 31 front spring shackles and did some work on the spring.
Today I noticed when lifting the car on the lift, or lifting each side with a jack, the shackles didn't move the same on the left and right and appeared to be binding. How tight or loose should the shackles slide into the perch? Should they need to be hammered in, or slide in with a push of the hand or, lightly tapped in? They are making an effort to hammer them out. Last edited by old31; 10-02-2019 at 03:13 PM. |
10-02-2019, 03:49 PM | #2 |
Re: 31 Front spring shackles, how tight or lose?
