Old 10-18-2019, 03:56 PM   #1
56sedandelivery
56sedandelivery's Avatar
Default 56 door glass install
I am to the point of installing the lift on my door glass in my 56SD and have a question. I believe that it is installed on the glass with the short end toward the front with the bevel toward the outside. Is this correct?
56sedandelivery is offline   Reply With Quote
Old 10-19-2019, 09:01 PM   #2
Daves55Sedan
Daves55Sedan's Avatar
Default Re: 56 door glass install
There should be ONE radius corner of the glass. All the other corners are square. The radiused corner goes at the top rear of the door.
Old 10-19-2019, 09:18 PM   #3
Hot Rod Reverend
Hot Rod Reverend's Avatar
take a look here:
https://www.hotrodreverend.com/in-progress/tag/window
Lancaster, California
Visit hotrodreverend.com to view hundreds of pictures and videos of the build of the 1955 Ford Club Sedan!
Hot Rod Reverend is offline   Reply With Quote
Old 10-19-2019, 10:55 PM   #4
56sedandelivery
Originally Posted by Hot Rod Reverend View Post
That helps. I know the direction of the window and the short guide of the lift is to the front. My question is the direction of the guides for the rollers. In this pic, is this the inside or outside. I think it is inside but want to make sure.
https://static.wixstatic.com/media/c...8_1536_s_2.jpg
