01-28-2018, 05:01 PM | #1 |
Model B timing cover question
I have what I believe is a model B timing cover. Unfortunately it is covered with dirt and grease. I found a cover that looks just like it on eBay that is clean (attached picture). My question is: Do all model B timing covers have the elongated boss where the timing pin is located, which makes them easily identifiable? I am wondering if there are model B covers that look similar to model A covers - i.e. no elongated boss (making them harder to identify). It sure looks like the B and A covers have the same timing pin location from what I can see. The model B cover has a little different area where the generator mounting is. The left cover is what I believe is a B cover and the right cover is what I think is a model A cover.
Rusty Nelson |
01-28-2018, 05:33 PM | #2 |
Re: Model B timing cover question
Vince Falter/ Forever Ford has a website that shows the different variations of the covers
01-28-2018, 05:39 PM | #3 |
Vince's excellent website is located at: http://www.fordgarage.com/pages/timingcovers.htm. I think you will find that the cover on the left is actually a later Model A cover (that uses the same casting as the Model B cover) as identified by the hole for the timing pin being at the bottom of the elongated boss. The answer to your question is that all Model B covers have the elongated boss but so do some post production Model A covers.
Charlie Stephens Last edited by Charlie Stephens; 01-28-2018 at 05:46 PM. |
01-28-2018, 05:40 PM | #4 |
Rusty,
Both shown are Model A timing Covers, the dead giveaway is the location of the timing pin hole. The example on the left is a post production replacement used for both Model A replacement and Model B production. However the Model B example has the timing pin hole location at the other end of the elongated boss, See Vince Falters Ford Garage, here is a link: http://www.fordgarage.com/pages/timingcovers.htm Darryl from Fairbanks, currently warming in Florida Last edited by darrylkmc; 01-28-2018 at 05:46 PM. |
01-28-2018, 06:04 PM | #5 |
Thanks all for setting me straight on the covers. I thought the "B cover" looked similar to an A cover due to the timing pin location. However, the generator mounting is different from a model A cover - why?
Rusty Nelson |
01-28-2018, 06:13 PM | #6 | |
Bob |
