05-14-2020, 10:22 PM | #1 |
Steering wobbe
I am trying to diagnose the cause of a slight wobble in the steering of my 1929 RPU. This is not the dreaded “death wobble” but more a tendency to wander at cruising speed. There is no play at all in the 7-tooth steering box and pitman arm (checked on the bench with a dial guage) and the steering column is bolted tightly to the frame. Therefore I assume the problem lies “downstream” of the pitman arm, probably in the drag link and/or tie rod connections. I will investigate them shortly, but in the meantime I want to eliminate other possible causes that could be cheaper and easier to fix.
Just recently I did two things that seemed to worsen it: I pumped both front tyres up to 35psi and repacked the bearings in the LHS wheel. I tightened the wheel nut as per recommendations in this forum, so am hoping it is tight enough. I would be grateful for any further suggestions |
05-14-2020, 10:53 PM | #2 |
Re: Steering wobbe
What were the recommendations of this forum to tighten the wheel nut?
Charlie Stephens |
05-14-2020, 11:29 PM | #3 |
Re: Steering wobbe
What is the toe-in set at? Incorrect Toe (especially toe-out) can cause wandering.
05-15-2020, 08:24 AM | #4 |
Re: Steering wobbe
Ck toe-in. How old are the tires??
Why only repack one side wheel bearing?? Paul in CT |
05-15-2020, 08:45 AM | #5 |
Re: Steering wobbe
Alignment.
05-15-2020, 08:50 AM | #6 |
Re: Steering wobbe
05-15-2020, 09:40 AM | #7 |
Re: Steering wobbe
If everything is tight and wheels are straight/true I agree with toe-in.
Worried about the wheel bearing adjustment. Easy. Tighten nut while spinning wheel/drum just enough to make sure it just snug, back nut off to next or 2nd castle making sure wheel still spins freely. Install cotter. |
05-15-2020, 10:31 AM | #8 |
Re: Steering wobbe
In my case after changing out everything over the course of several years it was the spring perch nuts. Driver side was loose by 2.5 turns. Passenger side 3/4 of a turn. Snugged em down very tightly and and no more wobble.
05-15-2020, 10:45 AM | #9 |
Re: Steering wobbe
I hope that you verified that you have the proper nuts on there, the ones with the taper of the end that fits into the radius rod. And don't forget the cotter pins.
05-15-2020, 11:28 AM | #10 |
Re: Steering wobbe
Often the cause of wobble is looseness in the drag link ends. Check that and I recommend 1/8" toe in. Wheel bearings should be tightened very snug, rotate wheel a few times, then back off nut and re-tighten just enough to take out all the free-play. Check both wheels. Tie rod ends should be snug too. Wandering can be caused by castor and/or camber being off a little.
05-15-2020, 03:53 PM | #11 | |
Re: Steering wobbe
05-15-2020, 06:02 PM | #12 |
Re: Steering wobbe
Katy....you betcha! My initial fear is that the taper had wallowed but so far so good. I went through hell until I figured it out. I replaced everything imaginable. One of out club tech guys asked me if there was rust outside of the boss's. Prior to figuring things out there was indeed rust where there had not been prior.
05-15-2020, 08:33 PM | #13 |
Re: Steering wobbe
Jack up the front end under the axle and try to rock the wheels both 3-9, 6-12, and straight up and down. Any loose joints or king pin slop will be obvious. Also rotate the wheels to check for run out or other signs of a warped/bent rim. Please share the fix when you figure it out.
05-15-2020, 11:06 PM | #14 | |
Re: Steering wobbe
To tell you the truth, the recommendations were a little confused and contradictory, but the gist of it was that the nut should be tightened until the wheel starts to bind and then back off a quarter turn or to the nearest castellation hole for the split pin. Not too tight and not too loose, just like Goldilocks. |
05-15-2020, 11:09 PM | #15 |
Re: Steering wobbe
05-16-2020, 07:09 AM | #16 | |
Re: Steering wobbe
Your statement about wheel bearings is about right. 1/4 turn back off may be a bit much. Not to tight and not too loose is correct Toe-in is pretty much toe-in. Its pretty much a fits all. All cars need toe-in and the amount is usually 1/32- 1/8". Those numbers also work for an 'A', I prefer 1/23-1/16". |
