04-27-2020, 01:25 PM | #1 |
Coil , coil , coil
Hd to dig this up for another customer per email thought i would share . I have bought almost 200 of these over the last couple years and had a very low failure rate .....been a good alternative to the more expensive Bosch Blue ( my favorite ) Doesnt require a external resistor ......
https://www.amazon.com/Beru-Blue-Pri...8011518&sr=8-1 |
04-27-2020, 02:04 PM | #2 |
Re: Coil , coil , coil
Thanks for the tip. Back in the day, we used to run Beru spark plugs in our snowmobiles. As I remember, they were very good. The only thing wrong withm was that the insulator on them was PINK.
04-27-2020, 11:51 PM | #3 |
Same for me. I used Beru plugs in my Ski-Doo Elan back in 70`s. They were good...
Thanks for the tip. |
04-28-2020, 07:03 AM | #4 |
The best coil for a 1932 to 1948 Ford is a stock Ford coil rebuilt by
Skip Haney in Florida. He has been doing them over 20 years and well over 20,000 of them. Lets ask the readers how many are not happy with their coil he rebuilt. G.M.
www.fordcollector.com |
04-28-2020, 11:13 AM | #5 |
And now, after that commercial break, we will resume our regular programming about the coils used in just about every other application..
04-28-2020, 11:52 AM | #6 | |
Also, when does the ohm rating of a coil come into play? I've seen 1.5 & 3.2 ohms as choices. As much as I try, I have a hard time understanding electrical theory. |
04-28-2020, 01:21 PM | #7 | |
This can't be emphasized too strongly or too often. Rebuilt coils by Skip are the best!!!...
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 04-28-2020 at 03:51 PM. |
04-28-2020, 01:26 PM | #8 |
Tim, in simple terms you are just trying to get the proper current at the points. Because the amps, resistance and voltage are all related it is easy to just look at the resistance. In a 12v system that turns out to be in the 3.0 ohm range. So if you have a 1.5 ohm coil (which was the common one for a 6v system) and you couple it with a 1.5 ohm ballast resistor you are at around 3.0 ohm overall. Or you can use a 3.0 ohm coil in a 12v system and no ballast resistor. These are just round numbers for examples, but that's the general idea.
There are advantages to running a 1.5 ohm coil with a ballast resistor, which is similar to why Ford ran the ballast resistor with the original 6v coils. But, for simplicity it is easier to just run the 3.0 ohm coils with 12v. So, 1.5 ohm coil + 1.5 ohm ballast resistor = 3.0 total ohms Or just a 3.0 ohm coil = 3.0 total ohms Last edited by JSeery; 04-28-2020 at 01:36 PM. |
04-28-2020, 03:04 PM | #9 | |
likely see more of the same. It's important new people know how to keep their old Fords running. G.M.
04-28-2020, 03:20 PM | #10 | |
To little, that is much below 3.5 and it won't start or may just catch as you leave of the starter button. The engine is still spinning and the voltage go's up a little and the engine fires. To much voltage and the points arc and point life is reduced. The large diameter original resisters are best. I don't like the skinny little replacements they seem to get to hot for me. The main thing people have to be careful of is leaving the ignition switch on. If the points are closed then the coil becomes a big resister and melts the material in the coil and can even crack the case. I know this is repetitive but if it saves one coil it's worth it. And NO they don't work with Petronx. G.M.
04-28-2020, 03:25 PM | #11 |
GM, believe that is original Ford coil information, I was responding to 12v "tin can" coils. I like Fords original design with the ballast resistor and think they are good idea for the 12v systems for the same reasons Ford used them. But in a modified vehicle you can get by without them.
I'm sure ignition switch being left on has been the death of many a coil! On the original Ford coil/ignition circuit (which I have very limited experience with ), I believe the coils are in the .7 to .8 ohm range and the total circuit specification is 1.0 to 1.35 ohms. So that would leave the ballast resistor in the .3 to .55 range. And I think they are spec'd at .36 ohms cold and .56 ohms hot. Last edited by JSeery; 04-28-2020 at 03:54 PM. |
04-28-2020, 03:34 PM | #12 | |
coil?? G.M.
04-28-2020, 03:38 PM | #13 |
I am going to get Skip to run some heat tests on a coil that is
left on with the points closed to see how fast and how hot it gets. G.M.
04-28-2020, 03:54 PM | #14 |
04-28-2020, 05:34 PM | #15 | |
