07-06-2017, 06:41 PM | #21 |
Re: Continuing engine problem
I would check you cooling system out before pulling the engine.
Radiator, water pump, etc. If the engine is as per factory spec's and seizing when it only gets really hot. Sounds to me like you have to keep it cool. Also, what oil weight have you been using to break motor in? Another idea, timing along with cooling problems, knocking? Seizing only when very not, why is engine getting that hot? |
07-06-2017, 10:19 PM | #22 | |
We set ring gaps to .013 top, .011 middle, .009 bottom. It also looks like Aluminum in the rod bearing babbitt, which won't hurt anything. I never use pistons with out expansion slots! Herm. |
07-07-2017, 07:25 AM | #23 |
Ray your on the right track measuring everything until you find that which is too tight
Here are some you have not posted piston ring side clearance piston ring back space valve stem to guide valve lifter to bore camshaft journal to bore and the list goes on but any of these can lock a hot engine |
07-07-2017, 08:02 AM | #24 |
Pistols and bores look awful from the seizures. Maybe you could get by with new pistons and honing the bores for proper clearances. I'd check your radiator. Mine has one of the cheap 2 row radiators from the 70s. It will overheat easily when the ambient temp is over 80 degrees, so I usually drive in the mornings until I can install a 3 row radiator.
Engines typically see peak temperatures during a hot shutdown when heat soak occurs. If the piston clearances are too tight seizures occur like you are seeing. Good luck Sent from my SM-J727V using Tapatalk
1929 (early) Model A Special Coupe - restored to original 1964 Buick Wildcat convertible |
07-07-2017, 08:29 AM | #25 |
700rpm . My Bad, , aircraft field. acft owners want to fly as cheaply as they did in the 50s,and 60s. When mechs made 1.50 2.00 an hour. You could buy flying planes for 800 to 1000 dollars. Same here.
07-07-2017, 10:03 AM | #26 |
_________________________________________ 1931 Ford Model A Tudor 1930 Ford Model A Deluxe Roadster 1930 Ford Original Rolling Chassis- Restoring |
07-07-2017, 10:42 AM | #27 | |
07-07-2017, 10:47 AM | #28 |
Years ago, and through the end of the 1940's many of us used to hear stories where hundreds of poor, single car, Model A owners used to drive up to a Sears Store, drop off their worn out, oil leaking and oil burning, smoking Model A's, and after a few days hitch a ride back to Sears to pick them up with a very good totally "rebuilt" Model A engine.
This "Model A Maintenance" procedure was supposedly done by Model A owners almost as often as changing their Model A tires ........ and there were almost no "rebuilt" engine complaints afterwards. Here within the past twenty (20) years of reading Model A Forum stories, and our changing from much needed and typical everyday "Model A Maintenance" ...... to a sideline hobby of "Model A Restoration" ..... we often hear that "rebuilt" Model A engines today often appear to be almost a total disaster. In trying to assist other future Model A owners needing "rebuilt" Model A engines, anyone care to share their thoughts as to maybe, .......... Why is it like this today? LOL |
07-07-2017, 10:55 AM | #29 |
I agree with Herm about the pistons being tight. The pattern on the skirts look real odd,
NOT uniform. There also could be a problem with the "ledge" at the bottom of the bore, being too sharp! The ring groove depth may be to shallow which could cause the lack of cross hatch. Ya,..you have trash in the rod bearings,..hopefully it's Aluminum.. You can run solid skirt piston,..BUT, you need to know how much "cam" is ground in the pistons,...the more cam, the tighter the clearance. The reverse hold true,..less cam, then you need MORE clearance.. YOU need to find an "engine builder" that understand all this AND MORE, to correct your problem,..he needs to check things most have never head of or thought of ! I have $4,000-$5,000( probable more) in tools to measure areas of an engine..and I've done this for almost 43 years. Herm and I are in the same boat.. One last question,...on the INSIDE of the piston, in the crown(the top) is there any color (caramel), or is it still Aluminum color? Dudley |
07-07-2017, 11:20 AM | #30 | |
I don't know if they hold up longer, I haven't had anybody bring either back. But I think the neoprene runs cleaner. Thanks, Herm. |
07-07-2017, 12:29 PM | #31 |
On the flow test, this video shows how I do it. I think I could set it up without removing the rad from the car. Hope to try that soon. If you can find a high flowing water source, it would be much easier, but I tried the output from two garden hoses and that is not near enough water. You need about 36 GPM and that is hard to find. Maybe at a fire house.
Anyway, keep the top tank full while you measure the water rate out of the bottom. The bucket and stop watch work pretty well after you average a couple of runs. https://www.youtube.com/watch?v=I0O4...rIa0r_fFQcz4R0 Your final test is being able to run a steady 45MPH for 10 minutes. Most of the cars in our club can't do this. Do this , even on a cool day. Still works. |
07-07-2017, 05:53 PM | #32 | |
The bottom edge of the sleeves does seem sharp. How does the ring depth affect the crosshatch? The rod bearings are good; some of what you're seeing in the pix is just some shop handling debris, since cleaned off. There is no metal debris present, nor was there any in the oil, pan, or dipper tray when I dropped the pan. I don't understand what you are referring to on the "cam" in regard to pistons. The shop that did the sleeves and honing is Portland Engine Rebuilders, well respected and reputable. They confirmed yesterday that the cylinders were honed to 3.875 and the pistons fitted to .003. This may be the problem. They measured the pistons yesterday also, and they still read 3.8720. The inside tops of the pistons are aluminum with no discoloring of any sort. I have also ordered a new Brassworks radiator. As long as I'm spending money, I might as well spend it all!
07-07-2017, 06:18 PM | #33 | |
I ordered a new Brassworks radiator today, but I may clean out my existing and keep it as a spare.
07-07-2017, 06:22 PM | #34 |
07-07-2017, 07:08 PM | #35 |
You can clean out the tubes with chemicals and stuff if there is flow in the tubes. A plugged tube will not be affected by anything in the coolant running by it. You need mechanical cleaning and Very few shops will tackle the job of taking that top tank off.
Good move on the new core. |
07-10-2017, 10:40 AM | #36 | |
2. Some rings are wider than others (for the depth of the grooves), IF the ring does not rest below the land when you push it in the land,..it will put excessive pressure on the cylinder walls,..make sense? 3. "cam in the piston",....Pistons are not round(more like an egg),..smaller near the pin bosses. When I started out building race engines, the pistons had very little cam and the clearance was in the .008"-.009" range,..to keep them from sticking. They started putting MORE cam in the pistons and now the clearance is in the .0025"- .0035" range. That will seal-up the holes better and not "barrel face" the rings from the rocking motion on the pistons. 4. Heat and the radiator,..the inside of the pistons,...Best guess,..since there is no color on the inside of the pistons(that's heat),..your problem could just be that the pistons were set too tight in the holes,..I'd put more clearance in the cylinders. BTW,..the "color, caramel" is oil that has stained the inside of the piston,..when the piston is running at optimum temperature,..I look for this when I freshen an engine.. Dudley |
07-10-2017, 10:51 AM | #37 | |
I keep reading about newly rebuilt engines that are running badly and often wondered why. One case in particular..Aguy had his v8 rebuilt and it ran perfectly on the engine stand but after installing it in his ear it didn't have enough power to even move the car! Great rebuild!! Last edited by FrankWest; 07-10-2017 at 10:56 AM. |
07-10-2017, 11:32 AM | #38 |
Actual re-built Model A engine experiences from 60 years ago compared to reading Model A Forum Post for the past 20+ years:
Similarly, when we observe fine vintage furniture from 100 years ago built with hand tools, vintage houses and window sashes built 100 years ago with hand tools, and actual hand writings of the last century, one can begin to see a noticeable difference in developed hand and eye coordination, talent, and most importantly, a sense of pride and a standard of care. Appears today, many are bringing Model A engines to guys with five (5) thumbs who write notes that resemble a ball point pen attached to a chicken's leg while getting its neck wrung. Just be careful ...... and do not be surprised if you hand him a hand saw and a hand plane and ask him to build a table ...... like your re-built Model A engine ..... it could resemble careless chain saw type rough carpentry. Last edited by H. L. Chauvin; 07-10-2017 at 11:33 AM. Reason: typo |
07-10-2017, 01:10 PM | #39 |
I know nothing about engine rebuilding, but know watchmaking. Any well running watch or clock mechanism, is one that is not tightly bound, but a movement with a little slop so that it will not freeze up and become bound under force. I would imagine that fitting the piston/cylinder walls and piston rings, must be carefully fit so as not to bind up yet provide a proper vacuum for the engine to run..Seems like an almost impossible task..Much much more than just replacing old parts with new ones.
07-10-2017, 02:32 PM | #40 |
Hi Frank,
Per your #39 mentioned precise watch adjustments, in our rural area, Babbitt bearings were properly adjusted without thickness gauges from the 1820's on steam boats until the 1950's, all without today's so-called hi-tech "Plasti-Gage". That's about 230 years of adding and removing shims until "no" up & down bearing movement was felt; but easy movement from side to side experienced ..... just one (1) age old method always taught by our local engine re-builders because it always worked. A constantly flowing oil film is not only required for lubrication, but also for cooling metal to metal frictional movement. "Too tight" has always caused two (2) types of many past Model A mechanical failures" "Too tight" to pay for qualified professional engine re-building services is usually the most common one. |
Thread Tools | |
Display Modes | |
