05-21-2020, 09:51 PM | #21 |
Re: B Carb and B Distributor
Been playing with the initial timing. Seems to be good with an initial of 18. Is that correct?
05-22-2020, 12:13 AM | #22 |
Id say its too far advanced if your readings are correct.Ive found 8 degrees initial to be optimal for me,but my compression is 7.5 to 1,running a late b cam,holley 94 and header,my volumetric effciency is higher than a stock configuration..
05-22-2020, 05:14 AM | #23 |
I started out at 9 but the engine runs toward the warmer side. I am still running the stock A head and carb.
05-22-2020, 06:35 AM | #24 |
I believe Mac's is selling "B" points and condensers now. Also, don't forget the "B" dizzy uses slightly longer bronze spark plug leads. I finally put a "B" dizzy on my '31 roadster and it is probably the best thing I've done for it.
Bob-A |
05-22-2020, 08:42 AM | #25 |
How would you verify “10” percent.
05-22-2020, 01:10 PM | #26 |
05-22-2020, 02:00 PM | #27 |
I still prefer the original distributor , its less complicated . I like having the ability to retard and advance the distributor myself . I'm use to it and consider it as part of the model A charm ..
05-22-2020, 02:11 PM | #28 |
I posted in the wrong place .
