04-24-2018, 04:00 PM | #1 |
Rear brake
What keeps the housing for the cam shaft from rotating in the rear backing plate?
John |
04-24-2018, 04:10 PM | #2 |
Re: Rear brake
rivets
04-24-2018, 04:29 PM | #3 |
Re: Rear brake
I'm talking about the housing with the grease fitting that the brarings are in, I replaced the track assembly and the housing rotates in the track.
John |
04-24-2018, 07:39 PM | #4 |
Re: Rear brake
The housing should not rotate, talk to the supplier you purchased the rear brake track assembly from.
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? |
04-25-2018, 06:27 AM | #5 | |
Re: Rear brake
John |
04-25-2018, 09:25 AM | #6 | |
Re: Rear brake
I had a loose one and welded it solid w/the wire feed, while it was in place.
04-25-2018, 05:10 PM | #7 |
Re: Rear brake
Thread Tools | |
Display Modes | |
