04-09-2014, 11:39 AM | #1 |
Axle-Nut Torque
Hi all,
Just curious, what's the torque spec for the axle nuts on a 1936 Ford rear-end? I did a search but it wasn't conclusive. Also, aside from going out and getting a really expensive torque wrench how do you guys achieve this figure? It's quite high, isn't it? Thanks! - Craig |
04-09-2014, 11:57 AM | #2 |
Re: Axle-Nut Torque
175-200 lbs-ft
dickspadaro.com |
04-09-2014, 12:32 PM | #3 |
Re: Axle-Nut Torque
Have a 175-200lbs person stand on the end of a 1-foot long breaker bar.
-WANTED-
Pre-War Speed Equipment Davies or Morrison Intake Manifold 77-6050B, 81AS - 81SB - 99AS - 99SB 19AS cylinder heads |
04-09-2014, 01:34 PM | #4 |
Re: Axle-Nut Torque
04-09-2014, 02:14 PM | #5 |
Re: Axle-Nut Torque
Here is the spec I usually refer to that was posted on BillB's Flathead Techno Site.....
In Reply to: Re: Torque value of axle nut posted by JWL from 02-ocil-01f.dial.optilinkcomm.net (216.128.152.157) on Thursday, June 13, 2002 at 8:32PM : The 'V8 Times', Sept/Oct 98 Issue, pages 46 and 48, quotes several Ford Service Letters and later corrections. The final direction on tightening axle nuts reads: "tighten nut 356074-S to 200 to 220 foot pounds; then continue tightening to the next castellation providing final resultant torque does not exceed 275 foot pounds."
04-09-2014, 06:52 PM | #6 |
Re: Axle-Nut Torque
Its important that the taper fits well and is clean and dry.
04-09-2014, 08:26 PM | #7 | |
Re: Axle-Nut Torque
I wonder, with so much torque do the threaded portions of the axles ever break off? My car's axle shafts looked A-ok but still, I'd hate to have the end snap and then have to tear the whole rear apart again to replace the shaft, though I guess that's better than losing the wheel while driving, LOL! |
04-10-2014, 06:12 PM | #8 |
Re: Axle-Nut Torque
04-11-2014, 06:36 AM | #9 | |
Re: Axle-Nut Torque
Karl: I think your Math is wrong, Wouldn't the 100 lb. person have to stand @ the 1' mark. You forgot to consider the the person has two feet all ready. LOL / LOL |
