Old 01-25-2020, 02:16 PM   #1
qmdv
qmdv's Avatar
Default Large axle nuts
I have only used the larger axle nuts in the past and most of the rodders back in the day in LA area used them as well. Common auto parts store item in the early 1960's. Uses 1 1/4" socket
I have only the two left that I am using on my 32 project. Are there any available. Have not seen them lately
qmdv is offline   Reply With Quote
Old 01-25-2020, 02:49 PM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: Large axle nuts
Those wheel STUDS are at least two threads too short....no joke! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 01-25-2020, 02:52 PM   #3
qmdv
qmdv's Avatar
I do know that. I should have put that disclaimer in my post
Old 01-25-2020, 03:29 PM   #4
tubman
tubman's Avatar
And, of course, for anything like this, you should try Fred at "Southside Obsolete" ("barnfind08" on here).
Old 01-25-2020, 04:59 PM   #5
supereal
supereal's Avatar
If you are seeking the large nut on the end of the axle, C&G has them.800/266-0470. Part number 1155A, $1.75. Also order the special washer that goes under the nut. Number 351505-S8. Fifty cents. It is a special thick washer and must be under he axle nut.
supereal is offline   Reply With Quote
Old 01-25-2020, 06:34 PM   #6
Kpar
Kpar's Avatar
I must be missing something I searched C&G site and "1155A" and it came up invalid ?.
Kpar
Kpar is offline   Reply With Quote
Old 01-25-2020, 07:15 PM   #7
petehoovie
petehoovie's Avatar
Kpar - See this link for Nut > https://cgfordparts.com/ufolder/ford...p?number=1155A
Washer
at this link > https://cgfordparts.com/ufolder/cgca...&sp=Search+%23
The only thing nice about being imperfect is the joy it brings to others....
"Silver rings, your butt! Them's washers!"
"We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969
https://www.youtube.com/watch?v=7NReUd2_0u0
Old 01-25-2020, 10:35 PM   #8
34fordy
34fordy's Avatar
Be careful what you buy if not original Ford nuts. Those being harder than the
"Hubs of Hell. Henry knew how to "makem hard"
34fordy is offline   Reply With Quote
Old 01-26-2020, 12:43 AM   #9
Kpar
Kpar's Avatar
Yes already been caught with previous purchase of brake parts.
I have sent a request to Barnfind08 for some.
Kpar
Old 01-26-2020, 02:11 PM   #10
grumppyoldman
grumppyoldman's Avatar
If a file will cut the nut it's not wise to use them, threads will pull out and cause all kinds f crap to happen. Al
grumppyoldman is offline   Reply With Quote
Old 01-27-2020, 12:27 AM   #11
JM 35 Sedan
JM 35 Sedan's Avatar
I also have a couple of those large rear axal nuts on one of my cars, but would like to find more as well to use on other cars. If you are successful in finding a source for these larger version axel nuts....please post that info here on this thread. Thank you
John
Old 01-27-2020, 08:00 AM   #12
Terry,OH
Terry,OH's Avatar
You may be missing the hard washer under the nut and the gasket under the washer. Barnfind08 did have the nuts.
Old 01-27-2020, 08:44 AM   #13
tubman
tubman's Avatar
Terry, it's good to know he had the nuts; does he have the washers and gaskets too?
Old 01-27-2020, 09:55 AM   #14
Zeke3
Zeke3's Avatar
I didn't know there should be a gasket under the washer. I think I see it in the 1937 Chassis Parts List, but it is not identified with a part number. What type of material is it made of?
Zeke3 is offline   Reply With Quote
Old 01-27-2020, 10:17 AM   #15
KGS
KGS's Avatar
C&G has them. Part# B-1183
KGS is offline   Reply With Quote
Old 01-27-2020, 10:41 AM   #16
Zeke3
Zeke3's Avatar
Thanks!
Old 01-27-2020, 01:15 PM   #17
JM 35 Sedan
Those hard fiber washer's or gaskets also come in the Best Gasket sets sold for banjo rears. Third Gen Automotive sells the gasket sets, not sure if they sell the washers/gaskets separately.
Plus, make sure the steel washers that go between fiber washer and nut are definitely there, and of the proper hardness, or your torque readings for the axel nut may not be accurate.
John
Thread Tools
Display Modes
