Old 08-06-2019, 07:25 PM   #1
Mulletwagon
Mulletwagon's Avatar
Default Choke
Been starting up the 31 a few times a week for the last six months. Although it immediately fires up and idles nicely, I have never needed to use the choke. Is that pretty typical in warm weather or is my carb especially rich ? The float level is set at exactly 5/8 inch.
Mulletwagon is offline   Reply With Quote
Old 08-06-2019, 07:46 PM   #2
Joe K
Joe K's Avatar
Default Re: Choke
May be normal for the Florida Panhandle.
You could try covering your gas line with clip-on clothes-pins to reduce gas line temperature if you feel compelled to choke. Isn't that what is done to prevent vapor lock?
Joe K
Shudda kept the horse.
Old 08-07-2019, 11:27 AM   #3
katy
katy's Avatar
Default Re: Choke
If you start it up and only let it run for a few minutes before shutting it off, that's a big NO NO.
You should be running it, preferably driving it, for at least 20 or 30 minutes, so that it get's hot enough to get rid of any condensation.
Don't go away mad, just go away.
