09-11-2019, 05:41 PM | #1 |
6 volt compaiison positive ground LED tail light, brake light stop light
This is a side by side comparison of LED bulbs vs 21/3 CP bulbs (the original bulbs that came with the car). The LED bulbs are "Plug and Play", as they fit the original sockets without any modification to the electrical system or the car. The advantage is they draw a fraction of the amperage (on your old wiring) and are allot brighter and cooler.
My car is a 1953 Mercury with a 6 volt positive ground electrical system. The sequence is Daylight then Night, running lights on, brakes lights, left turn signal and then right turn signal. Daylight = LED's on right, Night = LED's on left I bought the LED brake/stop/running lights from: www.ledlight.com Contact by Email SALES & SUPPORT - [email protected] Contact by Phone Toll Free 1 (877) 283-5060 Local 1 (602) 997-0366 https://www.ledlight.com/searchresul...KeyWords=64854 1154 LED Bulb 6 Volt. BAY15D base 1154. 60 LED Light bulb. Very bright up to 950 Lumens brake light. Up to 750 Lumens taillight. Operates 6V positive ground or 6V negative ground. BAY15D base 2 contacts tail light and brake light. One bayonet is higher than the other for 1157. Long life up to 30,000 hours. Comparable to a 35 to 55 watt halogen or incandescent lamp. CE and Rohs listed. The leds are optically aligned to the reflector for maximum led light output. Up to 70 CP candle power output. Dim-able with a variable voltage supply.The BAY15D base is 15mm diameter with one bayonet indexed and two contacts. The maximum overall length M.O.L. 1.944 inches. The maximum diameter is 1.058 inches. Compatible with: BAY15D Honda CT70 Honda Z50 utube video: https://www.youtube.com/watch?v=AwQm...ature=youtu.be Last edited by Merc Cruzer; 09-11-2019 at 09:04 PM. |
