Old 08-08-2020, 05:59 PM   #1
dbtenner
dbtenner's Avatar
Default 34 Roadster - Brakes Shuddering
Hi all,
I’m experiencing shuddering in the brakes (car starts to shake too) on a ‘34 roadster when coming to a stop, about 10% of the time. Still have the original mechanical brakes, never touched them. Just curious if anyone has advice on where to start for troubleshooting/fixing?
Thank you so much! I appreciate it.
dbtenner is offline   Reply With Quote
Old 08-08-2020, 06:25 PM   #2
petehoovie
petehoovie's Avatar
Default Re: 34 Roadster - Brakes Shuddering
Brake shoe lining material - 'woven'?
https://www.mcmaster.com/friction-material/
"We shot our way out of that town for a dollar's worth of steel holes." - from 'The Wild Bunch' - 1969
Old 08-08-2020, 07:22 PM   #3
DavidG
DavidG's Avatar
Could be contamination such as grease on one or more brake shoes.
Old 08-09-2020, 04:08 AM   #4
David J
David J's Avatar
Very good point .
I have had success with this by cleaning shoes-drums with brake cleen and lightly sanding the shoes . Just to de-glaze them .
The zerks on the rear axle ends can be a major problem if greased a lot .
David J is offline   Reply With Quote
Old 08-09-2020, 09:29 AM   #5
Will D
Will D's Avatar
If it is grease or gear oil contaminate it is best to replace the shoes/pads however you can boil it out if they are saturated. Extreme caution should be exercised with a fire extinguisher for gas on hand.
Remove the brakes from the car, go to a safe place well away from the car. Dip the shoe in gas, ignite, then wipe away oil/ grease as it bubbles to the surface after flame has subsided. Depending on the level of saturation you may need to repeat a few times.
Will D is online now   Reply With Quote
Old 08-09-2020, 11:03 AM   #6
DavidG
DavidG's Avatar
Very creative!
Old 08-09-2020, 02:20 PM   #7
Ron Pilger
Ron Pilger's Avatar
helpful post!
Ron Pilger is offline   Reply With Quote
Old 08-09-2020, 03:44 PM   #8
FlatheadTed
FlatheadTed's Avatar
It could also be Brake shoes not centered ,brake floaters can help this ,or has helped in the past ,
http://www.flatheadted.com
Old 08-09-2020, 05:22 PM   #9
A bones
A bones's Avatar
Very creative!
I would prefer to use alky.
Enjoy yer day. Tom
Hate can't fix what it started.
A bones is offline   Reply With Quote
Old 08-10-2020, 12:12 PM   #10
jimvette59
jimvette59's Avatar
He has mechanical brakes. Maybe just a wobble. Check the front end for ware.
jimvette59 is online now   Reply With Quote
Old 08-10-2020, 02:03 PM   #11
DavidG
DavidG's Avatar
No front wheel bearing grease seals until the '35 models.
Old 08-10-2020, 03:05 PM   #12
FlatheadTed
As Vett ,Check the perch bolts and wish bone ball ,king pins wheel bearings ,
