05-11-2018, 05:53 AM | #1 |
Afraid I opened a can of worms
Just dropped the oil pan on my '31 truck. Found some chips of what I assume is babbitt material in the third sump of the baffle. This engine has not been rebuilt as far as I can tell. Looking for opinions as to my best options. I inherited the truck and just want to take it out occasionally. Not looking to have it rebuilt.
05-11-2018, 06:07 AM | #2 |
Re: Afraid I opened a can of worms
I guess it could be something else. Will a magnet pick them up?
John |
05-11-2018, 06:25 AM | #3 |
Usually, a good indication of rebuilt vs original is that Ford used steel connecting rod shims and after market are brass.
05-11-2018, 06:34 AM | #4 |
No the chips are not magnetic
05-11-2018, 07:23 AM | #5 |
Did you run it before you opened it up? Any scary noises?
Back when we were teens, with all the answers we would have cleaned out the pan, bolted it back on and drove it without worrying. Now being much more sophisticated we fix-em, listen for every little sound and worry if we hear one. For an occasional driver: Check for any play in the rods at the crank, If tight, it's your call. Also get a Triple A membership because as your age you will no longer hear some of the strange sounds. Except the ones in your head. |
05-11-2018, 09:48 AM | #6 | |
Bill Justoutofbed
05-11-2018, 12:44 PM | #7 |
OR, get some hearings 'aids', and figure out how not to lose them...as they are very expensive !! As to OP query , if you've done the hard work of dropping the pan, etc....why not take the rod cap of off the suspect rod and look it over ? If it is real bad, maybe you can locate a substitute rod (?), if not so bad, meaning Babbitt mostly good integrity, well..your choice. Just like a 'can o worms', if you leave ONE bad/dying/decaying worm in a can of lively worms...guess what will eventually occur ? Last edited by hardtimes; 05-11-2018 at 12:47 PM. Reason: .............. |
05-11-2018, 09:39 PM | #8 | |
That is not true, Ford, like ALL the engine manufactures, used brass. You NEVER put steel, against steel, especially like the cheap tempered steel shims that Ford used for replacement service, in the 40's. Herm. |
05-12-2018, 05:46 AM | #9 |
For piece of mind, it is not that hard to take off the caps one at a time and inspect them.
Ken
Style beats speed any day, and with a lot fewer tickets. |
05-12-2018, 05:54 AM | #10 |
You'd be surprised how much metallic stuff can be in your sump, Inspect the rods if you must be but may be ...not as bad as you'd think.
<Link> This is how we roll<Link> "I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob Outcasts rules of old cars #1 Fun is imperative, mainstream is overrated #2 If they think it is impossible, prove them wrong #3 If the science says it impossible you are not being creative enough. #4 No shame in recreating something you never had #5 If it were not for the law & physics you would be unstoppable |
05-13-2018, 08:04 AM | #11 |
Thanks everyone. I appreciate all your advice.
05-13-2018, 10:55 AM | #12 |
Photos of metal pieces as they appear in dipper tray would help.
Sometimes these turn out to be chunks of rod bearing side thrust babbit and are not a serious problem unless rod is loose and banging around. Last edited by Benson; 05-18-2018 at 02:48 PM. |
05-13-2018, 11:03 AM | #13 |
How was it running before you took the pan off?
If you were happy with it. Clean the pan and put it back on. Model A engines can take a lot of abuse or use. Maybe run a little heavier oil, 20w-50, with a bottle of STP. Mavel Mystery Oil in gas for valves. 200 to 300 miles per year? Even a really worn out engine could last ten to twenty years. There great cars. Enjoy. |
05-13-2018, 11:16 AM | #14 |
If the car was mine and the rods are tight on the crank, and the engine is quiet, I'd put the pan back up and drive it gently, certainly not over 40 miles an hour and listen to it now and again by putting your ear on the top of the shift lever in neutral, in the quiet of your garage and see if you hear any distressing sounds. There are times when it is best to close the can of worms rather and make things worse. Lube and change oil every 500 miles and enjoy until the sounds change. Ernie
05-14-2018, 08:02 PM | #15 |
Thanks again everyone. Car was running well when I started restoration 10 years ago. I am in the process of straining the sludge to get an idea of how much junk was in the pan. I tried to post a picture but having some problems resizing to fit parameters.
05-14-2018, 11:11 PM | #16 |
If it is a bad connecting rod babbbit, Bert's sells re-babitted rods singly. Measure the crank and order a new rod from Bert's I changed all 4 of mine. Takes some work but at least I am not worried about a god failing or seizing on my old engine. A lot cheaper than a rebuild.
05-17-2018, 03:49 PM | #17 |
Shirt
Did you pull the engine? Or do it while the engine was in the car? |
05-17-2018, 09:18 PM | #18 |
When I set the rod and main clearances, cleaned the pan, replaced the timing gears, both cam and crank, etc etc, I pulled the engine.
It's so much easier to work on. More fun to stand there and work than lay under with oil dripping etc. It's not that difficult. Get an engine stand and an adapter, and find a place that will rent an engine hoist. You can check the clutch,throw-out bearing, pilot bearing and pressure plate, even bush the clutch shaft if needed. I learned a lot and everything got a thorough going over.....
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 |
05-17-2018, 09:40 PM | #19 |
you can also set bearings with aluminum foil...if you still have shims,remove the cap,fold and measure a piece to aluminum foil (I found heavy duty foil folds in half to .002),stick a 1" wide measured .002 piece in the cap,torque back on.gently try to turn the crank,not much,just a touch..if it turns,pull a shim from each side just till it doesn't turn..voila!!! .002 no go,so .00175 clearance...way easier than plastigage..just remember to turn the crank no more than a nudge when fitting..the idea is to just wedge the crank at .002...this method is faster and easier when working under the car...another tip is to let the car sit without starting for 2 days before pulling the pan,let the oil drip out for as long as you can.
05-17-2018, 09:54 PM | #20 |
and since you are already there,pull the head and slap a set of rings on it..lap the valves and she's fresh as a daisy..
