Old 07-16-2018, 05:25 AM   #1
big job
big job's Avatar
Default Zoo Mfg. Co.
The subject of reverse flushing few months ago. This has been in our shop
since the 1930's . These really work excellent. Somebody here wanted a
pic so here it is. If you come across one of these buy it.. sam
big job is offline   Reply With Quote
Old 07-16-2018, 05:41 AM   #2
Frank Miller
Frank Miller's Avatar
Default Re: Zoo Mfg. Co.
My dad made one out of a sand blasting gun. There are separate shuyoffs for the water and air. I let the block fill up and then hit the air button blowing the water out of the block.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 07-16-2018, 07:27 AM   #3
Kurt in NJ
Kurt in NJ's Avatar
I have 2, work great, if you take a 3' long piece of straight hose it will toss a "bucket" of water on someone 20 feet away
Kurt in NJ is online now   Reply With Quote
Old 07-16-2018, 10:26 AM   #4
Tim Ayers
I have the KR Wilson version of this. I haven't used it yet, but understand they work pretty well.
Tim Ayers is online now   Reply With Quote
Old 07-16-2018, 02:31 PM   #5
51504bat
51504bat's Avatar
The shop at the dairy I worked in after I got out of the service had one. We used it a bunch. I found one a couple of years ago at a swap meet. Had to tell the guy what it was. I think I paid 10 bucks for it. Never know when it will come in handy.
Old 07-16-2018, 06:08 PM   #6
Russ/40
Russ/40's Avatar
Nifty setup the tool. Never knew they existed. I have always run a water hose and the nozzle of my air line in the bottom of the radiator, and stuff rags around them. Full water flow with sporadic gusts of pressurized air really does the trick.
Old 07-17-2018, 08:15 AM   #7
Seth Swoboda
Seth Swoboda's Avatar
Can someone please explain to me in detail how this tool works? I get the basic idea but I'm interested to know more.
Old 07-17-2018, 08:32 AM   #8
Tim Ayers
Water goes through it, via a hose connection and then it also hooks up to a compressor. The air pushes the water through under high pressure. The combination of water under pressure clears out gunk that just compressed air or normal water pressure won't.
Old 07-17-2018, 12:17 PM   #9
Seth Swoboda
Thanks Tim!
