07-09-2016, 03:00 PM | #1 |
fuel pump push rod lengths on 1937 ford
Hello fellow Barners I have a '37 85hp. sedan with a cast iron intake manifold. My book calls out a 7.87inch pushrod for an alum. intake but says nothing for the cast iron. Can anybody tell me what push rod I should be using?
Thanks Rich |
07-09-2016, 03:19 PM | #2 |
Re: fuel pump push rod lengths on 1937 ford
ONE inch LONGER for iron. DD
07-10-2016, 11:23 AM | #3 |
Thank you D.D.
Rich |
07-10-2016, 12:17 PM | #4 | |
DD is correct in that your non-authentic intake requires a rod 1" longer than the original equipment.
07-10-2016, 02:12 PM | #5 |
I believe that in 37 the cast iron intakes were used on trucks.
Kerry |
07-10-2016, 03:08 PM | #6 |
