Old 04-11-2020, 03:20 PM   #1
LEM
LEM's Avatar
Default Pilot bearing fit
Is the pilot bearing to the transmission input shaft Press fit? My brand new pilot bearing ID to Transmission input shaft seems to be a very tight press fit.
LEM is offline   Reply With Quote
Old 04-11-2020, 03:48 PM   #2
abachman3
abachman3's Avatar
Default Re: Pilot bearing fit
Yes it is a press fit and the outer part does not spin.
abachman3 is offline   Reply With Quote
Old 04-11-2020, 04:33 PM   #3
midgetracer
midgetracer's Avatar
The pilot bearing is a press fit to the flywheel, but not a press fit to the input shaft of the transmission. If it was you would not be able to install the transmission.
midgetracer is offline   Reply With Quote
Old 04-11-2020, 04:37 PM   #4
J Franklin
J Franklin's Avatar
Check the dimensions to see which part is wrong. Are you sure there are no burrs anywhere? it should be a slip fit on the transmission.
Old 04-11-2020, 07:16 PM   #5
Patrick L.
Patrick L.'s Avatar
What Midgetracer and J said.
Old 04-12-2020, 10:23 AM   #6
katy
katy's Avatar
Bearing should be # 6203, 17mm ID, 40mm OD & 12mm wide.
Old 04-12-2020, 11:42 AM   #7
LEM
LEM's Avatar
Does anyone have an idea what the transmission input shaft diameter should be?
My shaft is .696 diameter and my bearing is .667 ID.
Old 04-12-2020, 02:41 PM   #8
Patrick L.
Patrick L.'s Avatar
Well, thats a heck of a lot more than a press fit. What number is your bearing ?
Old 04-12-2020, 03:00 PM   #9
J Franklin
J Franklin's Avatar
Go find a bearing that fits. That was a very common one used on many makes and models of vehicles. My model A my tractor and a mustang I once owned had the same pilot bearing. How was the fit on the old bearing or did things get changed out? I went out and measured an A input shaft and see .6562. So what is your shaft out of? You apparently have the correct bearing for sure.
Old 04-12-2020, 03:05 PM   #10
LEM
LEM's Avatar
The bearing is A7600 per the package it came in.
Old 04-12-2020, 04:01 PM   #11
Y-Blockhead
Y-Blockhead's Avatar
Something is not right... The A7600 bearing is a common bearing in Fords up to the 60's and beyond. ID .667. As someone asked, what is the shaft out of?
As an alternative you could use the bronze replacement bushing and ream it out to fit? https://www.macsautoparts.com/ford_m...for-a7600.html
Old 04-13-2020, 12:39 AM   #12
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
I would take some emery cloth and sand the shaft. According to your measurements, you need about.029” I had a new nors shaft that wouldn’t go, and that’s what I did to get it to fit. Didn’t take much time to do.
Old 04-13-2020, 12:46 AM   #13
J Franklin
J Franklin's Avatar
Make sure the rest of the part is correct before modifying it.
Old 04-13-2020, 10:28 AM   #14
Russ/40
Russ/40's Avatar
IMHO, .029" is an awful lot of sanding. My choice would be to first side by side compare you have a compatible input shaft; which your problem suggests you dont.
Assuming it will work, go with the bronze bushing and size it as necessary.
Old 04-13-2020, 04:03 PM   #15
goodcar
Bratton's catalog description: TRANSMISSION MAIN DRIVE GEAR - U.S. made. The end of the shaft where the pilot bearing (11550) fits must be .668 diameter. If worn more then .002 (.666) then the shaft must be built up or replaced. A poor fit will cause the transmission to jump out of high gear. Will not fit Early 1928 transmission boxes.
goodcar is offline   Reply With Quote
Old 04-13-2020, 04:39 PM   #16
sofield
Anew bearing has an id of .670 Trans input shaft should be between .667 to .669
sofield is offline   Reply With Quote
Old 04-14-2020, 10:57 AM   #17
katy
katy's Avatar
17mm = .669"
Old 04-14-2020, 12:10 PM   #18
Russ/40
Russ/40's Avatar
Is your input shaft a new purchase from Brattons, since you reference them? If not and its an older used input shaft, someone must have repaired it to fit a bearing they had on hand. Either get the bronze bushing and ream to size or get a machine shop to turn it down to the proper size.
Old 04-14-2020, 12:59 PM   #19
goodcar
I didn't purchase a new input shaft from Brattons. I merely posted the description exactly as it appears in their catalog.
Old 04-14-2020, 01:23 PM   #20
Russ/40
Russ/40's Avatar
Have you decided what your going to do?
Where are you located?
