Old 03-23-2020, 07:55 PM   #1
goodcar
Default Crankshaft Tool
Does anyone know where I can get one of the tools to turn crankshaft when engine is sitting vertical when aligning flywheel housing?? Anyone have one for sale??
goodcar is offline   Reply With Quote
Old 03-23-2020, 08:23 PM   #2
Bob C
Default Re: Crankshaft Tool
The vendors have them. https://www.snydersantiqueauto.com/P.../model-a/tools
Bob C is online now   Reply With Quote
Old 03-23-2020, 08:43 PM   #3
goodcar
A good start but would need to be modified for dial indicator to be centered. Could cut out the center nut and weld a couple of half inch 90 degree pipe fittings on the outer edges for extension handles. Thanks, may give this a try.
Old 03-23-2020, 08:51 PM   #4
Y-Blockhead
You could try one of these bad boys... a little more expensive. https://www.snydersantiqueauto.com/P...earchByKeyword or make your own out of an old starter.
Or use a 1⅜"wrench on the ratchet nut on the other end of the crank.
Y-Blockhead is online now   Reply With Quote
Old 03-23-2020, 09:29 PM   #5
Bob C
Is this what your looking for??
File Type: jpg Dave's Model A from Lincoln, Ne , Part 2 142.jpg (51.1 KB, 119 views)
Old 03-24-2020, 08:28 AM   #6
Nosetime
Nosetime's Avatar
Bob, who made that exactly? If, we ever get back to a swap season that's on my list. Thinking KR Wilson?
Nosetime is offline   Reply With Quote
Old 03-24-2020, 09:22 AM   #7
Bob C
Krw a320
Old 03-24-2020, 09:34 AM   #8
goodcar
Yes
Old 03-24-2020, 10:48 AM   #9
katy
katy's Avatar
What's wrong with just using a socket on the crankshaft pulley nut?
Play it again Sam.
Old 03-24-2020, 06:04 PM   #10
goodcar
Awkward to use with pulley end of engine pointing down. Prefer to use a tool designed for the job, much easier.
