Old 03-04-2017, 03:58 PM   #1
ford-m
ford-m's Avatar
Default What do I have here
Today was digging through stuff day and I found this little fella.
Is it a grease thingamajigi ??
ford-m is offline   Reply With Quote
Old 03-04-2017, 04:00 PM   #2
J Franklin
J Franklin's Avatar
Default Re: What do I have here
Yes model t era and some later water pump and throwout collars.
Old 03-04-2017, 04:27 PM   #3
JDupuis
JDupuis's Avatar
Yes, Model T, hit'n'miss engines, old farm implements.... Jeff
Let's let pylons, be pylons!
JDupuis is offline   Reply With Quote
Old 03-04-2017, 11:55 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
Also used on farm equipment and line shaft bearings. That's the first time I've seen one with a square shaft and spring to keep the cap positioned in quarter turn increments. It may have been used on some machine that had a lot of vibration. I've never heard of a cap unscrewing before from ordinary running, even on my hit and miss connection rod grease cup.
Old 03-05-2017, 06:35 AM   #5
ford-m
ford-m's Avatar
Hay Tom, this was posted yesterday. Is this my little gadget on top?.
https://www.fordbarn.com/forum/showthread.php?t=216067
Old 03-05-2017, 07:11 AM   #6
aermotor
Tom, I have run many hit & miss engines with grease cups including several with cups on the rod bearings and never had one come loose. I believe the spring device is more for service than cap retention, ie - one click every X number of hours or in ford-m's case X number of miles. Not that familiar with model A's but I have not seen it discussed or mentioned in any H&M information.
John
aermotor is offline   Reply With Quote
Old 03-05-2017, 09:58 AM   #7
Tom Wesenberg
Yes, it looks like it, but I'd like to see the inside of the bellhousing.
I'm wondering what that part greased?
Old 03-05-2017, 10:54 AM   #8
Randy in ca
Randy in ca's Avatar
Clutch release bearing lubrication for 1932-34. Not sure if used on all models - 1933 4-cylinder had it for sure. One of the experts like DavidG on the EV8 forum will likely know for sure
Randy in ca is offline   Reply With Quote
Old 03-05-2017, 12:53 PM   #9
Tom Wesenberg
That's all I could imagine it was used for, but how does a stationary filling lube a sliding part?
Old 03-05-2017, 07:11 PM   #10
Miles in MN
Miles in MN's Avatar
They connected to the throwout hub with a flexible line.
Miles in MN is offline   Reply With Quote
Old 03-06-2017, 07:00 AM   #11
aermotor
Is there any service instructions with this installation that would verify my theory in post # 6?
For sure less vibration here than bouncing around on a rod bearing cap.
John
Old 03-06-2017, 12:44 PM   #12
DougVieyra
DougVieyra's Avatar
Post # 1: "Is it a grease thingamajigi ?"
The correct name is 'whatchmacallit', Latin, from the Greek "whazit", from the original Sanskrit "Dohickee".
But for our purposes, 'thingamjogi' will work. Some like to shorten the word to 'thingamajig' leaving off the last letter (i).
DougVieyra is offline   Reply With Quote
Old 03-06-2017, 02:06 PM   #13
ford-m
ford-m's Avatar
Yea made my day 😁
