04-29-2016, 09:13 AM | #1 |
Gas tank strainer
I installed a new gas tank strain in the filler neck as my A didn't have one. Its a 31 and the strainer does not have threads or clips it just lays on top of flange and is a lose fit, maybe causing a rattle. Is this the way they fit? thanks ...
04-29-2016, 09:50 AM | #2 |
Re: Gas tank strainer
The original intent of the design was to serve as a spark arrestor. Unless yours is made from S/S, there is a potential for it to rust/corrode adding more junk to collect in the tank.
With current gas pumps being grounded through the hose, static sparks are not the problem they once were when the A was originally built - Back then most pumps were gravity fed and not properly grounded. Bottom line, if it isn't fitting properly or hits the fuel gage arm, you would likely be better off to return it - Creates more problems than it solves.
I Love Anything That Turns Money Into Noise |
04-29-2016, 10:23 AM | #3 |
I took the flash arrestor out of my tank almost 30 years ago. In this day and age they are not necessary and make filling the tank a real PITA. If one is worried about static sparks you can touch the tip of the gas nozzle to something metal away from the tank opening such as the cowl band right before you stick it on the tank opening.
04-29-2016, 11:36 AM | #4 | |
and dont get back in the car while its filing, your butt rubbin on the seat creates a charge like rubbin a balloon on someones hair... so when you get back out and touch the pump handle a spark is created where there are a whole lotta fumes. and if the unfortinate happens and theres fire coming out of the gastank DO NOT remove the nozzle, run away and find the emergency shutoff button located on the pavillions poles and the fire extinguisher thats out there.
1929 Model AA - Need long splash aprons! |
04-29-2016, 01:25 PM | #5 | |
Quite true about not sliding in and out of the car while fueling. Also never fuel a can of gas IN the car take it out and sit it on the ground. Only takes a micro second to burn yourself up in an accident. |
04-29-2016, 01:36 PM | #6 |
04-29-2016, 01:36 PM | #7 |
some of the (later) '31's had threads in the tank fill hole, requiring the early model A style arrestor. No vendors apparently sell new threaded ones now. You may have the type that just drops in (with tabs that fit in slots), which hopefully answers your question.
