My grandaddy passed away in Sep., this weekend I brought home the beloved 40' Ford. I was told that a 50' Ford truck motor had been put into the car at some point. How can I tell if I am looking at a 40' or 50' for V8?
![]() Sent from my iPhone using Tapatalk |
First give away is the distributor and then the thermostat necks. Makes it a 49 to 53 motor. 49 to 52 truck motor were basically a bolt in with the water pumps oil pan and exhaust manifolds
If you started with a 49 to 53 ford car motor you would have to swap the pieces i mentioned above. 53 truck motor had different wanter pumps and bellhousing which also have to be changed. |
Definitely a 49 and up engine.
Curious on how the vacuum to the distributor is hooked up. Looks like the vacuum line goes to the inside. For these distributor, vacuum sourcedfrom the carb?
#4 | |
![]() Quote:
Thank you for the info. The car runs pretty good but has an antifreeze leak. I was looking at starting with the cheaper hoses and cables and beginning to redo the car piece by piece. Thank you again. Sent from my iPhone using Tapatalk |
Makes me glad I have a flathead six... way simpler!
lets see the rest of the car!!!
#9 | ||
![]() Quote:
And we need some pictures of the whole car. Last edited by rich b; 03-26-2017 at 11:58 PM. Reason: more |
After enlarging the photo my feeble eyes do see the line as you say.
Nice car.
Don't forget to add the wire for the temperature sending unit. If possible, please post more photos of the car, including the engine compartment and interior. The posted photo is too large. Enjoy. |
Ask and ye shall receive.
![]() ![]() ![]() ![]() ![]() ![]() Sent from my iPhone using Tapatalk |
#13 |
Nice looking old Tudor Sedan. It looks like a more durable vinyl trim set was installed at some point. Looks to be set up for driving. Sure a lot of fun driving them.
#14 |
#15 |
TAsh,
I have a '40 standard Tudor as well. You have a nice car, drive the hell out of it! |
#16 |
TAshcraft: Thanks for posting those extra photos.
Beautiful car. "Standards" have an "agressive" look. I like the fact that it came with a roll of duct tape just in case a radiator hose bursts. Is that round shaped item under the dash a heater? For safety sake add a bolt on LED brake /taillight to the bumper brace if you don't install one in the rear fender. Having an original clock instead of the plain Standard glove box door is neat. Dual exhausts too. |
#17 | |
![]() Quote:
Yes it is a heater, the switch is under the dash and a light comes on through it once it is on. Sent from my iPhone using Tapatalk |
#18 |
BadAssTash.....very nice !
#19 |
You can never have enough duck tape !
#20 |
FYI, the glove box door is from a '40 Deluxe.
