Old 03-29-2021, 05:37 PM   #1
oriondal
oriondal's Avatar
Default Speedometer pickup
I bought a car whose speedometer wasnít working. I removed the speedometer pickup which appears to be in good shape. I fed both the old cable and a new one well into the housing. The gear spins but doesnít engage the cable. The cables both are square on the ends, so Iím wondering if the receiving end in the pickup is worn out (itís impossible to see up in there). Is this something that happens? If so, is there any remedy besides buying a new assembly?
oriondal is offline   Reply With Quote
Old 03-29-2021, 06:07 PM   #2
Bob C
Default Re: Speedometer pickup
Maybe your turtle takes the keyed cable instead of the square.
Old 03-29-2021, 06:27 PM   #3
oriondal
oriondal's Avatar
I think that may be the situation.. I see you can buy the correct speedometer drive gear shaft, but I can’t see how to disassemble the speedometer pickup case. It’s not in Les Andrew’s volume one so it must be pretty simple but I haven’t figured it out yet.
