Old 01-01-2019, 08:14 PM   #1
kimeccles
kimeccles's Avatar
Default 68B Cab chrome door garnish tube bolts?
Hi,
These are the tube bolts for the window front door chrome on a 68B. I re-chromed the molding garnish.
I have 4 long tubes and one shorter one. I think I need to have all 6 of these, but did not know if all the same size or not. If different where does the smaller one go? I only have half the other end screws in chrome, and I think the tabs on the garnishes are bent to hold, but not sure.
Any advice on what is right and if you have a few of the tubes or bolt ends so I can install these, please let me know.
Thanks,
Kim
68B frame# late May1930, fixed seat, Briggs build plate# & most parts, indicate July, or early Aug. 1930.
kimeccles is offline   Reply With Quote
Old 01-02-2019, 01:00 PM   #2
kimeccles
kimeccles's Avatar
Default Re: 68B Cab chrome door garnish tube bolts?
I have been informed by a forum member that my front window garnish should be woodgrain. Oh well, I chromed mine because it was rusty chrome to start and was probably original metal.
I also found 3/8 long tube bolts and screws like the one short one pictured. However, I do not know what is right. I have 4 tube bolts 1/2 inch long and one 3/8 inch long. I just ordered 10 of the 3/8 long versions from AZ A"s. I need 6 total depending on what size is right.
But not sure if Cab in mid 1930 is same as A400 on these tube bolts.
thanks, Kim
Old 01-02-2019, 02:22 PM   #3
jw hash
jw hash's Avatar
you have the wrong tube nuts, look under hardware in Snyder`s, they are #6 counter sunk tube nuts, the slant window bodies use #8 tube nuts. all the nuts are the same length it is the screws that are different.
jw hash is offline   Reply With Quote
Old 01-08-2019, 11:45 AM   #4
kimeccles
kimeccles's Avatar
Thanks for the info on tube nuts.
Is there supposed to be a thin piece of felt glued into the side of the front window molding U shaped channel shown in my middle picture? Mine had some type of felt, but not seeing it on pictures?
Old 01-08-2019, 11:23 PM   #5
jw hash
jw hash's Avatar
no felt, but on the early 68A`s some had a wood insert on the back side. your should not have anything but the wind lace.
