Old 01-01-2019, 11:39 AM   #1
spinelll
spinelll's Avatar
Default Oil drain sealer
I'd like to use a bit of sealer on the little oil drain tube that runs out of the main bearing. Does it require a high-temp sealer?
Ultimate copper or the permatext red?
spinelll is offline   Reply With Quote
Old 01-01-2019, 11:48 AM   #2
AL in NY
AL in NY's Avatar
Default Re: Oil drain sealer
That drain pipe has tapered pipe threads and it shouldn't need sealer, particularly because there's no oil pressure on it. If your worried about it coming unscrewed, try some JB Weld on it.
AL in NY
AL in NY is offline   Reply With Quote
Old 01-03-2019, 07:23 AM   #3
spinelll
spinelll's Avatar
Thanks Al.
You're right of course about the thread but when the pipe is tightened snug, it's not oriented the correct way. I have to back it out about a 1/4 turn for it to be pointing in the right direction. Thus the need for a sealer.
Old 01-03-2019, 11:17 AM   #4
daveymc29
daveymc29's Avatar
As mentioned, JB Weld
daveymc29 is offline   Reply With Quote
Old 01-03-2019, 07:52 PM   #5
AL in NY
AL in NY's Avatar
You can use a 1/4 pipe tap and very carefully tap the hole slightly deeper. Just do a 1/4 turn at a time. Tap once, re-try your drain pipe. Not right......tap again and re-try. Keep doing this until the pipe is tight and in the correct orientation. Don't tap it too deep or you may restrict the oil flow.
AL in NY
Old 01-04-2019, 07:32 AM   #6
aermotor
What about a good cleaning and some type of Loctite?
John
aermotor is offline   Reply With Quote
Old 01-04-2019, 10:10 AM   #7
Aretino
Aretino's Avatar
Try using a product called "Tight Seal". Tight Seal is similar to a pipe thread compound.
Aretino is offline   Reply With Quote
