04-12-2018, 11:10 AM | #1 |
Front Motor Mount Adjustment
How tight should the center bottom nut be on the front motor mount yoke be? Should it compress the springs? Just tight enough to get the cotter pin in the castle nut?
04-12-2018, 11:51 AM | #2 |
Re: Front Motor Mound Adjustment
I found on my ccpu that if the spring was overly compressed there was more noticeable vibration, especially on deceleration.
I would go with the "just tight enough to get the cotter pin in...."
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 |
04-12-2018, 12:10 PM | #3 |
Thanks!
04-12-2018, 12:20 PM | #4 |
Re: Front Motor Mount Adjustment
Welcome to The Barn!
Which Model A do you have?
04-12-2018, 12:55 PM | #5 |
Yup just tight enough to slip cotter in.
04-13-2018, 10:03 AM | #6 |
I know the voices aren't real but damn they have some good ideas! |
04-13-2018, 10:40 AM | #7 |
Funny Red, I never heard it called Cotter.
Learn something new every day. LOL |
04-13-2018, 06:31 PM | #8 |
They're actually a split pin! Cotter pins are an entirely different thing.
04-13-2018, 06:37 PM | #9 |
Uncle google knows...
cot·ter pin ˈkädər ˌpin noun noun: cotter pin; plural noun: cotter pins; noun: cotter; plural noun: cotters a metal pin used to fasten two parts of a mechanism together. a split pin that is opened out after being passed through a hole.
04-13-2018, 10:55 PM | #10 |
Yea well its a cotter pin round these parts :P
04-14-2018, 04:10 PM | #11 |
It's been a cotter pin all of my 82years.
04-14-2018, 05:27 PM | #12 |
Only 82 years! Heck, people believed he earth was flat for centuries. Refer to 1955's post.
04-15-2018, 06:05 PM | #13 |
They have been called "cotter pins" for at least 133 years. Before I was born!
Jeff |
04-15-2018, 06:51 PM | #14 |
You guys have changed the terminology of a few things over the years. When did the ring gear move from the flywheel to the diff? I don't know how these things happen but they do - evolution?
04-15-2018, 07:32 PM | #15 |
Well it is "really" a cotter key where I come from...
68B frame# late May1930, fixed seat, Briggs build plate# & most parts, indicate July, or early Aug. 1930. |
04-15-2018, 07:44 PM | #16 |
Here is another USA patent for a Cotter pin.
I have never seen one of these.
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? |
04-15-2018, 07:47 PM | #17 |
The Cotter Key was invented by an Irish man named John Cotter in 1922. Originally used to hold fastners together on cabinets, Cotter keys found other purposes that seemed to be better suited than for that reason, such as, holding the Nuts on a bolt.
